example
longer
example
here
Nextcloud version (eg, 20.0.5): 28.0.3
Operating system and version ( Ubuntu 22.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 8.1
A multitude- to start:
- Opens without issue on a computer (windows). Does not open on an iOS mobile browser. Does not open/connect on iOS app either.
- Weather widget on dashboard doesn’t load.
- Widgets on dashboard (email, files, calendar) don’t typically load
- Hitting “calendar” (for example) doesn;t actually load. Stuck showing background theme picture. Theming is turned on.
- I can reliably click into folders and see everything, but if I hit refresh enough there’s a good chance something doesn’t load. If another user looks at files simultaneously, we can replicate one of us losing visual of the file.
That’s just the start
- Reinstalled entire nextcloud vm 17 times now. No luck (from this instructional, on proxmox) Documize
{"reqId":"7AjHSSBsE8rZS3CdqvqF","level":3,"time":"2024-03-14T05:15:19-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"index","method":"GET","url":"/apps/logreader/api/poll?lastReqId=HNLhvKkw0qPMTCDYzH2L","message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":169,"Previous":{"Exception":"TypeError","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"poll","class":"OCA\\LogReader\\Controller\\LogController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php","Line":102},"message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","exception":{},"CustomMessage":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102"}}
{"reqId":"2gxCnHYQLdCyTh7gIMAm","level":3,"time":"2024-03-14T05:15:30-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"index","method":"GET","url":"/apps/logreader/api/poll?lastReqId=HNLhvKkw0qPMTCDYzH2L","message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":169,"Previous":{"Exception":"TypeError","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"poll","class":"OCA\\LogReader\\Controller\\LogController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php","Line":102},"message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","exception":{},"CustomMessage":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102"}}
{"reqId":"tz6Qj5MNiul3Gj8dmqH6","level":3,"time":"2024-03-14T05:15:41-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"index","method":"GET","url":"/apps/logreader/api/poll?lastReqId=HNLhvKkw0qPMTCDYzH2L","message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":169,"Previous":{"Exception":"TypeError","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"poll","class":"OCA\\LogReader\\Controller\\LogController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php","Line":102},"message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","exception":{},"CustomMessage":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102"}}
{"reqId":"aphr5vM1HKqAIgVOwCQq","level":3,"time":"2024-03-14T05:15:52-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"index","method":"GET","url":"/apps/logreader/api/poll?lastReqId=HNLhvKkw0qPMTCDYzH2L","message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":169,"Previous":{"Exception":"TypeError","Message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"poll","class":"OCA\\LogReader\\Controller\\LogController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php","Line":102},"message":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102","exception":{},"CustomMessage":"OCA\\LogReader\\Controller\\LogController::poll(): Argument #1 ($lastReqId) must be of type string, null given, called in /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php on line 230 in file '/var/www/nextcloud/apps/logreader/lib/Controller/LogController.php' line 102"}}
{"reqId":"PJL3SWbOnrsJzrvECdlD","level":3,"time":"2024-03-14T05:16:23-04:00","remoteAddr":"10.10.10.190","user":"--","app":"no app in context","method":"GET","url":"/apps/theming/image/background?v=11","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Security/Crypto.php","line":119,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":90,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":67,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/private/Session/CryptoWrapper.php","line":112,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":449,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":705,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Security/Crypto.php","Line":158,"message":"Could not decrypt or decode encrypted session data","exception":{},"CustomMessage":"Could not decrypt or decode encrypted session data"}}
{"reqId":"9LLhxGTwF9BqyqxgV8l3","level":3,"time":"2024-03-14T05:16:23-04:00","remoteAddr":"10.10.10.190","user":"--","app":"no app in context","method":"GET","url":"/apps/theming/image/logo?v=11","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Security/Crypto.php","line":119,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":90,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":67,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/private/Session/CryptoWrapper.php","line":112,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":449,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":705,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Security/Crypto.php","Line":158,"message":"Could not decrypt or decode encrypted session data","exception":{},"CustomMessage":"Could not decrypt or decode encrypted session data"}}
{"reqId":"qTIYOY6IgMUD39nKXAXd","level":3,"time":"2024-03-14T05:16:50-04:00","remoteAddr":"10.10.10.190","user":"--","app":"no app in context","method":"GET","url":"/ocs/v2.php/apps/notifications/api/v2/notifications","message":"Could not decrypt or decode encrypted session data","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"Exception","Message":"HMAC does not match.","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Security/Crypto.php","line":119,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":90,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Session/CryptoSessionData.php","line":67,"function":"initializeSession","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/private/Session/CryptoWrapper.php","line":112,"function":"__construct","class":"OC\\Session\\CryptoSessionData","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":449,"function":"wrapSession","class":"OC\\Session\\CryptoWrapper","type":"->"},{"file":"/var/www/nextcloud/lib/base.php","line":705,"function":"initSession","class":"OC","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1200,"function":"init","class":"OC","type":"::"},{"file":"/var/www/nextcloud/index.php","line":37,"args":["/var/www/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Security/Crypto.php","Line":158,"message":"Could not decrypt or decode encrypted session data","exception":{},"CustomMessage":"Could not decrypt or decode encrypted session data"}}
{"reqId":"oi3ivxGmHdG5FZVzBE83","level":2,"time":"2024-03-14T05:17:24-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: Doctrine\\DBAL\\Exception\\DriverException - An exception occurred while executing a query: SQLSTATE[HY000]: General error: 7 FATAL: terminating connection due to administrator command\nSSL connection has been closed unexpectedly\nserver closed the connection unexpectedly\n\tThis probably means the server terminated abnormally\n\tbefore or while processing the request.","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"clzMhDSkRN5dW2leEQhd","level":2,"time":"2024-03-14T05:17:47-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: OCA\\FullTextSearch\\Exceptions\\RunnerAlreadyUpException - Index is already running","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"o9hohKtktWOGK4Fw6bec","level":2,"time":"2024-03-14T05:17:48-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: OCA\\FullTextSearch\\Exceptions\\RunnerAlreadyUpException - Index is already running","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"G0taPyfh5eBVLTYs2Cb7","level":2,"time":"2024-03-14T05:17:49-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: OCA\\FullTextSearch\\Exceptions\\RunnerAlreadyUpException - Index is already running","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"E2UZTesZAhTsFw4uoffu","level":2,"time":"2024-03-14T05:17:50-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: OCA\\FullTextSearch\\Exceptions\\RunnerAlreadyUpException - Index is already running","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"kvuFAptBFaKLR1Y9eUpW","level":2,"time":"2024-03-14T05:17:51-04:00","remoteAddr":"","user":"--","app":"fulltextsearch","method":"","url":"--","message":"Exception while live index: OCA\\FullTextSearch\\Exceptions\\RunnerAlreadyUpException - Index is already running","userAgent":"--","version":"28.0.3.2","data":{"app":"fulltextsearch","level":"2"}}
{"reqId":"jpXSPbAn2a413JJwosby","level":2,"time":"2024-03-14T21:06:12-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"core","method":"POST","url":"/login/confirm","message":"Login failed: 'Sassriverrat' (Remote IP: '10.10.10.190')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","data":{"app":"core"}}
{"reqId":"lhsrxJaG0FLBT3UFt12T","level":2,"time":"2024-03-14T21:06:14-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"core","method":"POST","url":"/login/confirm","message":"Login failed: 'Sassriverrat' (Remote IP: '10.10.10.190')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","data":{"app":"core"}}
{"reqId":"v0YgjcsUb6VOu11aHSGv","level":3,"time":"2024-03-14T21:06:21-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"ocs_api","method":"POST","url":"/ocs/v2.php/cloud/users","message":"Failed addUser attempt: User already exists.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","data":{"app":"ocs_api"}}
{"reqId":"jO3O120OjYuS5P1MS4AU","level":3,"time":"2024-03-14T21:07:50-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"related_resources","method":"GET","url":"/ocs/v2.php/apps/related_resources/related/account?itemId=aparish&resourceType=talk&limit=5&format=json","message":"Exception thrown: OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound","Message":"","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","line":173,"function":"getRelatedResourceProvider","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","line":127,"function":"retrieveRelatedToItem","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/apps/related_resources/lib/Controller/ApiController.php","line":108,"function":"getRelatedToItem","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"getRelatedResources","class":"OCA\\RelatedResources\\Controller\\ApiController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":65,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","Line":605,"message":"","exception":{},"CustomMessage":"Exception thrown: OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound"}}
{"reqId":"0nYJMCy6hhtVQP23wlZE","level":3,"time":"2024-03-14T21:07:50-04:00","remoteAddr":"10.10.10.190","user":"sassriverrat","app":"related_resources","method":"GET","url":"/ocs/v2.php/apps/related_resources/related/account?itemId=aparish&resourceType=talk&limit=5&format=json","message":"Exception thrown: OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36","version":"28.0.3.2","exception":{"Exception":"OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound","Message":"","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","line":173,"function":"getRelatedResourceProvider","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","line":127,"function":"retrieveRelatedToItem","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/apps/related_resources/lib/Controller/ApiController.php","line":108,"function":"getRelatedToItem","class":"OCA\\RelatedResources\\Service\\RelatedService","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"getRelatedResources","class":"OCA\\RelatedResources\\Controller\\ApiController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":65,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/related_resources/lib/Service/RelatedService.php","Line":605,"message":"","exception":{},"CustomMessage":"Exception thrown: OCA\\RelatedResources\\Exceptions\\RelatedResourceProviderNotFound"}}
Not sure how to cleanly do this
PASTE HERE
PASTE HERE
PASTE HERE
I’m happy to let someone poke around or share a test set of credentials to demonstrate if it were easier.
