Is E2E encyption on NextCloud already implemented or must I load some 3th party application like CryptoMator, 7ZIP…?
End-to-End encryption is a mix of two things:
- an optional app called
end_to_end_encryptionthat you must install on the server (as long as you are not also using server-side encryption via theencryptionapp) - using one or more of the official Nextcloud clients (not Web since that you won’t be able to access your end-to-end encrypted files on the Web UI any longer by definition)
Anyhow to answer the question:
The above docs were recently extensively expanded.
Thank You. It is exactly what I was looking for. Encryption on the cliet side was the issue…
