EDIT:
Looking in the server logs I can see that I have a file missing, but I am not sure what should what should go in this JS file.
"message":"Could not find resource testapp/js/testapp-main.js to load"
EDIT 2:
I figured out part of the problem. I thought that the section_id
in the array returned by getSchema()
was the name of my section in the settings view. I confused this with the title
. The docs don’t really cover what these attributes are for so I was making assumptions.
Hello all!
I am trying to figure out how the declarative settings work. In my app I have some settings that are shown in the Administration Settings tab when you click on your profile icon. These settings are created using ISettings
and an entry in the info.xml
. I am wanting to switch this to the declarative settings if possible.
Here is my current test setup:
Test App
I created a test app using the app generator so I have a place to create the test settings.
I have created a Settings
directory with a file called DeclarativeAdminSettings.php
declare(strict_types=1);
namespace OCA\TestApp\Settings;
use OCP\IUser;
use OCP\Settings\DeclarativeSettingsTypes;
use OCP\Settings\IDeclarativeSettingsFormWithHandlers;
class DeclarativeAdminSettings implements IDeclarativeSettingsFormWithHandlers {
public function __construct() {
public function getValue(string $fieldId, IUser $user): mixed {
public function setValue(string $fieldId, mixed $value, IUser $user): void {
public function getSchema(): array {
return [
'id' => 'test_app_declarative_settings_form',
'priority' => 10,
'section_type' => DeclarativeSettingsTypes::SECTION_TYPE_ADMIN,
'section_id' => 'my_section_id',
'storage_type' => DeclarativeSettingsTypes::STORAGE_TYPE_INTERNAL,
'title' => 'TestApp Settings Title',
'description' => 'This is a description for the TestApp',
'doc_url' => '',
'fields' => [
'id' => 'testapp_field_key',
'title' => 'A Setting',
'description' => 'Description for A Setting',
'type' => DeclarativeSettingsTypes::MULTI_SELECT,
'options' => ['foo', 'bar', 'baz'],
'placeholder' => 'Select something damn it',
'default' => ['foo', 'bar'],
I then added the registration to the Application.php
as follows:
namespace OCA\TestApp\AppInfo;
use OCP\AppFramework\App;
use OCP\AppFramework\Bootstrap\IBootContext;
use OCP\AppFramework\Bootstrap\IBootstrap;
use OCP\AppFramework\Bootstrap\IRegistrationContext;
use OCA\TestApp\Settings\DeclarativeAdminSettings;
class Application extends App implements IBootstrap {
public const APP_ID = 'testapp';
/** @psalm-suppress PossiblyUnusedMethod */
parent::__construct(self::APP_ID);
public function register(IRegistrationContext $context): void {
$context->registerDeclarativeSettings(DeclarativeAdminSettings::class);
public function boot(IBootContext $context): void {
This lines up almost exactly with the Nextcloud docs, but I can’t see these anywhere. I also looked at the Files app as an example since it has declarative settings, but again I don’t see the Files app admin settings in the Administrator Settings tab. I am pretty lost as to how these settings are supposed to work. Any help would be greatly appreciated.
