I have a 128gb ssd and i want the files to upload to it, in external storages i enter name, local, name of the directory where the ssd is and its folder where i want the data to save, but a red circle with exclamation mark appeared and when i click on it nothing happens, so i don’t know what’s the error,under authentication i don’have any other option then none and i also tried adding admin under available for but it’s the same, the directory for the ssd that i added is
/media/markonjak/opi3_server/nc-data/
if i enter
/media/markonjak
i get a green circle, that means ok,
i replaced configuration with /media/markonjak, but when i try to upload to it it just says forbidden
i would be grateful is somebody can help me
, only one more problem, i noticed that when i upload a file to nextcloud, it firstly loads in the hdd of my pc and only then gets transfered to the external ssd, is this normal and can it be changed?
