I am using
$userSession->loginWithCookie($user, $token, $session);
I then check if user was successfully logged with
$ok=$userSession->isLoggedIn();
and I get a true.
Now I would like to go to Dashboard? How do I do that?
I am using
and I get a true.
The URLGenerator
followed by a RedirectResponse
may be what you’re looking for.
See either the the Dev Manual[1] (and server
code repo). Might also get some ideas from looking at the LoginController
(in server
What are you working on?
