Nextcloud AIO version (eg, 20.0.5): 4.4.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): nginx
PHP version (eg, 7.4): replace me
When i Click of Open Nextcloud keeps routing to same page
Can you post the docker-compose file or docker run command of AIO that you used, the nginx docker-compose or docker run command and your nginx config here?
server {
listen 80;
listen [::]:80; # comment to disable IPv6
if ($scheme = “http”) {
listen 443 ssl http2;
listen [::]:443 ssl http2; # comment to disable IPv6
include ./ssl.conf;
server_name nextcloud.sutradhar.tech;
location / {
resolver localhost; # Note: you need to set a valid dns resolver here or use 127.0.0.1 / [::1] instead of localhost in the line below. See https://stackoverflow.com/a/49642310 for a better explan>
proxy_pass https://localhost:9000$request_uri; # Note: you need to change localhost to 127.0.0.1 or [::1], if you don't use a valid dns resolver in the line above
proxy_set_header X-Forwarded-Port $server_port;
proxy_set_header Early-Data $ssl_early_data;
proxy_set_header X-Forwarded-Scheme $scheme;
proxy_set_header Accept-Encoding "";
proxy_set_header Host $host;
client_body_buffer_size 512k;
proxy_read_timeout 86400s;
client_max_body_size 0;
# Websocket
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
ssl_early_data on;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES12>
ssl_prefer_server_ciphers off;
You need to change proxy_pass https://localhost:9000$request_uri; to proxy_pass http://localhost:11000$request_uri; and it should work if your nginx should be running on the host and not inside a container.
The following Error used to occur hence updated to https
Bad Request
Your browser sent a request that this server could not understand.
Reason: You’re speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.
