example
longer
example
here
Nextcloud version (eg, 12.0.2): 17.0.3
Operating system and version (eg, Ubuntu 17.04): ubuntu-server 18.04.3
Apache or nginx version (eg, Apache 2.4.25): NGinx 1.17.4
PHP version (eg, 7.1): 7.3.14
The issue you are facing: unlink(/upload_tmp/oc_tmp_xyxyxyx): No such file or directory at /var/www/nextcloud/lib/private/Preview/Movie.php#98
So i’ve read that these errors are fixed in NC 18
So my question is, what will happen to my existing and working docker mechanism of ONLYOFFCIE if i upgrade to the next Nextcloud level. The changelog says, OO is included and makes docker installations obsolete. But in other forums i’ve read that the included OO is not as performant as the docker image in combination with the app.
Is anything known about accidents for that constellation by upgrading to NC 18?
If YES, how to avoid those accidents - what pre-conditions have to be made by admin before upgrading from 17 to 18?
The output of your Nextcloud log in Admin > Logging: unlink(/upload_tmp/oc_tmp_xyxyxyx): No such file or directory at /var/www/nextcloud/lib/private/Preview/Movie.php#98
Thanks for advices
