Nextcloud version _ 16.0.4
Operating system and version (eg, Ubuntu 17.04): Manjaro 4.19
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.1): 7.3.9
I’ve set up Nextcloud using Apache on my PC, when I go to Localhost, the Nextcloud page comes up with ‘Internal Server Error’
I can’t make sense of the error codes, and I’ve posted them twice here already without any answer, so I presume no-one else can make sense of them either (which isn’t a good sign).
But I don’t want to just give up, having got this far, so I’m trying a different tack. The first error code says something about permissions being denied. I want to know how to check whether I’ve got the file permissions right. What user:group runs Nextcloud - is it just the webserver or a new group? What directories will this user:group need access to and what access rights does it need?
- Install Nextcloud with Apache
- Go to LocalHost
PHP Warning: fileperms(): stat failed for /usr/share/webapps/nextcloud/data/nextcloud.log in /usr/share/webapps/nextcloud/lib/private/Log/File.php on line 140
touch(): Unable to create file \\/usr\\/share\\/webapps\\/nextcloud\\/config\\/config.php because Permission denied at \\/usr\\/share\\/webapps\\/nextcloud\\/lib\\/private\\/Config.php#240","userAgent":"Mozilla\\/5.0 (X11; Linux x86_64; rv:69.0) Gecko\\/20100101 Firefox\\/69.0","version":""}
