Square placeholders are shown instead of Chinese characters.
I updated Nextcloud to version 30.0.5 and NC Office to version 24.04.11.2 on Debian 12 with PHP 8.3.
The additional uploaded Arial fonts of Windows 11 now show up in the font menu and i can format the document using Arial fonts, but Chinese characters still donât work. Even if i format the document with the Liberation Sans font it doesnât work.
Your thread title asks âWhat is the difference between a NC Docker installation and Bare Metalâ, while your post does not mention âdockerâ at all and asks about how to get multi-byte characters to display.
You may consider changing the thread title to get replies that help in solving your problem, or change the post to reflect which differences you are interested in!
As for the fonts, for me Chinese and Lao work âout of the boxâ, but Thai stays square:
I tried a couple of fonts; most do show Chinese (top) and Lao (bottom), but none of them supports Thai. There is a package on Debian to support Thai fonts, I have it not installed and did not try if that resolved the issue.
This is Nextcloud âbare metalâ (Nextcloud on Debian + Yunohost in LXC container)
Collabora Online (CODE) Server = either a dedicated CODE instance (deployed via bare metal or a Docker image known as collabora/code)
Built-in Collabora Online (CODE) Server App = richdocumentscode
The integration app is required regardless of which Collabora Online deployment method youâre using.
Regardless of your CODE installation method: Collabora Online comes with some fonts⌠others will be picked up from installation environment (like tested above on Debian 12) and/or can be deployed by uploading manually via Nextcloud Officeâ>Fonts.
And, yeah, this should probably be better documented I guess.
