Are there clear system requirements available in documentation for those wanting to host local ai and the new nextcloud assistant?
I dont think there are clear system requirements available for local ai yet. Probably it also really depends on the model used.
I saw the video from Nextcloud where they present the Nextcloud AI Assistant.
I would like to active it, but I don’t know where.
I use the Version 27.0.3 (Nextcloud Hub 6)
Best wishes
Depends on your hardware. It is not well documented and you’ll need a beefy rig to run localai or similar. See OpenAI and LocalAI integration - Apps - App Store - Nextcloud
Take a look at this thread: A bit confused Hub 6 where is my local AI? - #10 by Byter
And you gonna also need to install the assistant app from the Nextcloud appstore.
Just a heads up, I couldn’t get it to work yet!
