/.well-known/caldav and carddav with haproxy
I know we can fix the caldav/carddav issue with the following lines when using traefik:
traefik.frontend.redirect.permanent: ‘true’
traefik.frontend.redirect.regex: https://(.*)/.well-known/(card|cal)dav
traefik.frontend.redirect.replacement: https://$1/remote.php/dav/
But does anyone have a working configurarion for haproxy?
I’m running Apache and I’d like to avoid edit the .htaccess file.
Regards
Hello @ErAzOr
You can try this:
acl caldav-endpoint path_beg /.well-known/caldav
http-request set-path /remote.php/dav/principals/users/%[query] if caldav-endpoint
use_backend nextcloud_backend if caldav-endpoint
would be nice when u share your experiences :v: :slight_smile:
you gave the right hint, but i had to config this:
    http-request set-path /remote.php/dav if caldav-endpoint
    use_backend nextcloud-http if caldav-endpoint
    acl carddav-endpoint path_beg /.well-known/carddav
    http-request set-path /remote.php/dav if carddav-endpoint
    use_backend nextcloud-http if carddav-endpoint
@abyss02 thank you. worked great.
for me, i just needed to add the following to the backend for nextcloud.
Working on this issue. I have nextcloud accessible with https://myserver/nextcould/
Does-it mean I have to replace the above by
acl caldav-endpoint path_beg /nextcloud/.well-known/caldav
http-request set-path /nextcloud/remote.php/dav if caldav-endpoint
acl carddav-endpoint path_beg /nextcloud/.well-known/carddav
http-request set-path /nextcloud/remote.php/dav if carddav-endpoint
thanks @uchagani those settings worked well for me.
In case anyone is using pfSense HAProxy, here are the frontend GUI settings that correspond:
Hello thanks to your indication, I have partially solved the problem as I believe something is missing in my case. For example n is the app if I open a video , I find an error that does not find the path :/remote.php/direct … similar to cardav . I believe there are other similar paths, so I ask you if you have changed or rather added other paths. Thank you
