No database drivers (sqlite, mysql, or postgresql) installed.
PHP modules have been installed, but they are still listed as missing?
Please ask your server administrator to restart the web server.
Went to another domain where there is a live version running to test and install in a different directory to ensure I can replicate the issue or in case the php settings are different.
That setup wizard appears to be too old. Imho one can no longer use it.
You can easily see this from the date of the script, which is from November 30th, 2021 and is still based on php7.3, so completely stale.
I am running 5 instances each for client projects on their domain accounts, in a hosted environment provided via VentraIP
Those all work brilliantly.
I replicated the php 8.2 settings from those functioning installs on the install I am trying to get sorted, and failing miserably.
All the settings on the file you referenced are functional in this problematic instance, as are the others.
I’m trying to get this nailed as I have two new client projects and will be conducting new installs on other hosting providers environments, that I’ve no experience of.
Figured I best get this one sorted properly before I venture into an unknown environment with unknown support levels.
Did a restore from back at November 2023 before I got more than a blank page.
Told me it wouldn’t run on php 8.2
Rolled back php to 7.4.28 and was finally able to get into the admin.
Admins at VIP cannot track it down at their end.
I was one version behind the latest which was got me on this journey.
