WebDAV Setup issues with Nextcloud Hub 25 Autumn (32.0.1)
With my new Nextcloud Hub 25 Autumn (32.0.1) I see below errors which may be causing to failure to login
Error :**
WebDAV endpoint
Your web server is not yet properly set up to allow file synchronization, because the WebDAV interface seems to be broken. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its `trusted_domains` or the `overwrite.cli.url`. This failure may be the result of a server-side DNS mismatch or outbound firewall rule.
Warnings :
  • JavaScript source map support
    Your webserver is not set up to serve `.js.map` files. Without these files, JavaScript Source Maps won’t function properly, making it more challenging to troubleshoot and debug any issues that may arise.
  • JavaScript modules support
    Unable to run check for JavaScript support. Please remedy or confirm manually if your webserver serves `.mjs` files using the JavaScript MIME type. To allow this check to run you have to make sure that your Web server can connect to itself. Therefore it must be able to resolve and connect to at least one of its `trusted_domains` or the `overwrite.cli.url`. This failure may be the result of a server-side DNS mismatch or outbound firewall rule.
  • OCS provider resolving
    Your web server is not properly set up to resolve “/ocm-provider/”, “/ocs-provider/”. This is most likely related to a web server configuration that was not updated to deliver this folder directly. Please compare your configuration against the shipped rewrite rules in “.htaccess” for Apache or the provided one in the documentation for Nginx. On Nginx those are typically the lines starting with “location ~” that need an update.
  • .well-known URLs
    Your web server is not properly set up to resolve `.well-known` URLs, failed on: `/.well-known/webfinger`
  • Errors in the log
    233 errors in the logs since November 13, 2025, 10:06:41 PM
  • Mimetype migrations available
    One or more mimetype migrations are available. Occasionally new mimetypes are added to better handle certain file types. Migrating the mimetypes take a long time on larger instances so this is not done automatically during upgrades. Use the command `occ maintenance:repair --include-expensive` to perform the migrations.
  • HTTP headers
    Could not check that your web server serves security headers correctly, unable to query `/heartbeat`
I tried searching for fixed issues I didnt find any.
My Compose.yaml is
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: always
container_name: nextcloud-aio-mastercontainer # This line is not allowed to be changed.
network_mode: bridge
volumes:
- nextcloud_aio_mastercontainer:/mnt/docker-aio-config # This line is not allowed to be changed.
ports:
- 8080:8080
environment:
#AIO_COMMUNITY_CONTAINERS: “local-ai memories” # Community containers https://github.com/nextcloud/all-in-one/tree/main/community-containers
APACHE_PORT: 11000 # Use this port in Nginx Proxy Manager
# NC_TRUSTED_PROXIES: 172.18.0.3  # this is the NPM proxy ip address in the docker network !
FULLTEXTSEARCH_JAVA_OPTIONS: “-Xms1024M -Xmx1024M”
NEXTCLOUD_DATADIR: /mnt/Sam1T/nextcloud/ncdata # ⚠️ Warning: do not set or adjust this value after the initial Nextcloud installation is done!
# NEXTCLOUD_MOUNT: /mnt/ # Allows the Nextcloud container to access the chosen directory on the host.
NEXTCLOUD_UPLOAD_LIMIT: 1028G
NEXTCLOUD_MAX_TIME: 7200
NEXTCLOUD_MEMORY_LIMIT: 1028M
NEXTCLOUD_ENABLE_DRI_DEVICE: false # Intel QuickSync
SKIP_DOMAIN_VALIDATION: false # This should only be set to true if things are correctly configured.
TALK_PORT: 3478 # This allows to adjust the port that the talk container is using which is exposed on the host. See https://github.com/nextcloud/all-in-one#how-to-adjust-the->
volumes:
name: nextcloud_aio_mastercontainer # This line is not allowed to be changed.
Can you help to suggest what is going wrong with my setup ?
