Hallo Leute,
ich brauch mal bitte eure Hilfe. Ich sichere mein Handy mit Swift Backup in die Nextcloud.
Seit 2 Tagen sichert er aber nicht mehr und nun sehe ich das im NC Protokoll:
[webdav] Fehler: Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[XX002]: Index corrupted: 7 ERROR: heap tid from index tuple (157,22) points past end of heap page line pointer array at offset 211 of block 74 in index “oc_filecache_pkey” at <>
- /var/www/html/3rdparty/doctrine/dbal/src/Connection.php line 1814
Doctrine\DBAL\Driver\API\PostgreSQL\ExceptionConverter->convert(["Doctrine\DBAL … "], [“Doctrine\DBAL\Query”])- /var/www/html/3rdparty/doctrine/dbal/src/Connection.php line 1749
Doctrine\DBAL\Connection->handleDriverException(["Doctrine\DBAL … "], [“Doctrine\DBAL\Query”])- /var/www/html/3rdparty/doctrine/dbal/src/Connection.php line 1163
Doctrine\DBAL\Connection->convertExceptionDuringQuery(["Doctrine\DBAL … "], “INSERT INTO "o … )”, [5,11,1710676537 … "], [2,2,2,2,2,"And … "])- /var/www/html/lib/private/DB/Connection.php line 295
Doctrine\DBAL\Connection->executeStatement(“INSERT INTO "o … )”, [5,11,1710676537 … "], [2,2,2,2,2,"And … "])- /var/www/html/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php line 354
OC\DB\Connection->executeStatement(“INSERT INTO "o … )”, [5,11,1710676537 … "], [2,2,2,2,2,"And … "])- /var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php line 280
Doctrine\DBAL\Query\QueryBuilder->execute()- /var/www/html/lib/private/Files/Cache/Cache.php line 315
OC\DB\QueryBuilder\QueryBuilder->execute()- /var/www/html/lib/private/Files/Cache/Scanner.php line 307
OC\Files\Cache\Cache->insert(“*** sensitive parameters replaced ***”, ["application/oc … "])- /var/www/html/lib/private/Files/Cache/Scanner.php line 240
OC\Files\Cache\Scanner->addToCache(“*** sensitive parameters replaced ***”, ["application/oc … "], -1)- /var/www/html/lib/private/Files/Cache/Scanner.php line 352
OC\Files\Cache\Scanner->scanFile(“*** sensitive parameters replaced ***”, 3, 66295, false, false)- /var/www/html/lib/private/Files/Cache/Updater.php line 130
OC\Files\Cache\Scanner->scan(“*** sensitive parameters replaced ***”, false, 3, false)- /var/www/html/apps/dav/lib/Connector/Sabre/File.php line 368
OC\Files\Cache\Updater->update(“*** sensitive parameters replaced ***”)- /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php line 149
OCA\DAV\Connector\Sabre\File->put(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1098
OCA\DAV\Connector\Sabre\Directory->createFile(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 504
Sabre\DAV\Server->createFile(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPut([“Sabre\HTTP\Request”], [“Sabre\HTTP\Response”])- /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit(“method:PUT”, [["Sabre\HTTP\ … ]])- /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod([“Sabre\HTTP\Request”], [“Sabre\HTTP\Response”])- /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start()- /var/www/html/apps/dav/lib/Server.php line 368
Sabre\DAV\Server->exec()- /var/www/html/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()- /var/www/html/remote.php line 172
require_once(“/var/www/html/a … p”)Caused by:
Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[XX002]: Index corrupted: 7 ERROR: heap tid from index tuple (157,22) points past end of heap page line pointer array at offset 211 of block 74 in index “oc_filecache_pkey” at <>
- /var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php line 103
Doctrine\DBAL\Driver\PDO\Exception::new([“PDOException”, … ]])- /var/www/html/3rdparty/doctrine/dbal/src/Connection.php line 1153
Doctrine\DBAL\Driver\PDO\Statement->execute()- /var/www/html/lib/private/DB/Connection.php line 295
PDOException: SQLSTATE[XX002]: Index corrupted: 7 ERROR: heap tid from index tuple (157,22) points past end of heap page line pointer array at offset 211 of block 74 in index “oc_filecache_pkey” at <>
- /var/www/html/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php line 101
PDOStatement->execute(“*** sensitive parameters replaced ***”)- /var/www/html/3rdparty/doctrine/dbal/src/Connection.php line 1153
Habe die Verbindung in SwiftBackup beendet und kann sie nun auch nicht mehr neu herstellen.
Vielleicht wisst ihr ja weiter
Zum System:
Neuste NextCloud AIO als Container aufm Pi4 mit SSD
