Nextcloud version: 22.2.3 - LinuxServer_Nextcloud docker
Operating system and version: Unraid 6.9.2
Unable to upload more than 100MB using WebDAV connection when nextcloud is proxied through cloudflare.
Use Cloudflare to proxy Nextcloud (security reasons)
Upload file larger than 100MB Results:
Nextcloud Client on Windows = success
Opening Website and using browser to upload = success
WebDAV connection with Windows PC = FAIL
WebDAV connection with Android app (not nextcloud) = FAIL
No errors in swag or nextcloud logs on my server when upload fails.
So, after a lot of testing I must conclude that Cloudflare limit is being hit: Cloudflare says under Network: Maximum Upload Size = 100MB
And that’s exactly the limit I hit when testing.
Changing Cloudflare proxy from “proxied” to “DNS only” WebDAV works.
Seems to me that WebDAV doesn’t utilize chunked upload?
Question
How to get WebDAV to work with a cloudflare proxy? Is this possible? What setting am I missing?
Contacted the developer of the Android app; he gave me the option to force chunking. Set that to 50MB and everything works just fine now. Uploading large files over WebDAV is not an issue anymore.
Weird thing is; I had already set chunksize server side to 50MB, but that doesn’t make any difference apparently? The user has to force chunking? That seems strange, no?
In Windows you don’t have that option? So in Windows the upload still fails with 100MB.
So question remains:
How to (really) force chunking server side?
Or how to do you set chunk size when using webdav as a user (on Windows)?
I am also running into this issue. I don’t remember running into this problem for more than a month or two. Is this a result of the changes with the Nextcloud sync for ver 23?
Yes, I already tried that, but that does not affect webdav connections at all. Upload is still cutoff at 100MB. It seems like you need to force chunking client side. After the dev of the android app implemented that and gave users the option to force chunking upload went fine.
So server settings does not seem to matter for webdav? Very strange…
