I have problem with NC server -
The web server is not yet properly configured enough to allow file synchronization because the WebDAV interface may be damaged.
I check 2 solution:
Solution 1
The Windows WebDAV Client might not support Server Name Indication (SNI) on encrypted connections. If you encounter an error mounting an SSL-encrypted Nextcloud instance, contact your provider about assigning a dedicated IP address for your SSL-based server.
Solution 2
The Windows WebDAV Client might not support TSLv1.1 / TSLv1.2 connections. If you have restricted your server config to only provide TLSv1.1 and above the connection to your server might fail. Please refer to the WinHTTP documentation for further information.
S1 - Certificate is same, and valid, date ok
S2 - we have TSLv1.2
Here is log from error:
1. OCP\App\AppPathNotFoundException: Could not find path for spreed | |
||2. Log Nextcloud|
Message":“Could not find path for spreed”,“Code”:0,“Trace”:[{“file”:"/var/www/html/nextcloud/core/Controller/SvgController.php",“line”:99,“function”:“getAppPath”,“class”:“OC\App\AppManager”,“type”:"->",“args”:[“spreed”]},{“file”:"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:166,“function”:“getSvgFromApp”,“class”:“OC\Core\Controller\SvgController”,“type”:"->",“args”:[“spreed”,“app-dark”,“000”]},{“file”:"/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",“line”:99,“function”:“executeController”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\SvgController”},“getSvgFromApp”]},{“file”:"/var/www/html/nextcloud/lib/private/AppFramework/App.php",“line”:126,“function”:“dispatch”,“class”:“OC\AppFramework\Http\Dispatcher”,“type”:"->",“args”:[{“class”:“OC\Core\Controller\SvgController”},“getSvgFromApp”]},{“file”:"/var/www/html/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php",“line”:47,“function”:“main”,“class”:“OC\AppFramework\App”,“type”:"::",“args”:[“OC\Core\Controller\SvgController”,“getSvgFromApp”,{“class”:“OC\AppFramework\DependencyInjection\DIContainer”},{“app”:“spreed”,“fileName”:“app-dark”,"_route":“core.Svg.getSvgFromApp”}]},{“function”:"__invoke",“class”:“OC\AppFramework\Routing\RouteActionHandler”,“type”:"->",“args”:[{“app”:“spreed”,“fileName”:“app-dark”,"_route":“core.Svg.getSvgFromApp”}]},{“file”:"/var/www/html/nextcloud/lib/private/Route/Router.php",“line”:297,“function”:“call_user_func”,“args”:[{“class”:“OC\AppFramework\Routing\RouteActionHandler”},{“app”:“spreed”,“fileName”:“app-dark”,"_route":“core.Svg.getSvgFromApp”}]},{“file”:"/var/www/html/nextcloud/lib/base.php",“line”:975,“function”:“match”,“class”:“OC\Route\Router”,“type”:"->",“args”:["/svg/spreed/app-dark"]},{“file”:"/var/www/html/nextcloud/index.php",“line”:42,“function”:“handleRequest”,“class”:“OC”,“type”:"::",“args”:[]}],“File”:"/var/www/html/nextcloud/lib/private/App/AppManager.php",“Line”:316,“CustomMessage”:"–"},“userAgent”:“Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:72.0) Gecko/20100101 Firefox/72.0”,“version”:“16.0.4.1”}
Anyone can help?
Krzysztof
