- Nextcloud Hub 10 (31.0.4)
- Version 7.0.1 2025-02-25
- I’m not sure how to find this
- jlesage/nginx-proxy-manager - latest
- PHP version (e.g, 8.3):
- Yes
- Not sure, but my logs are full with 10s of thousands of errors
- Docker in Unraid
- Cloudflare
I checked my Nextcloud and saw that there are 20-30k errors in logs.
All of those are about webdav not working and some permissions errors regarding the external folders that are attached.
But the ext folder setup looks ok on my end and when I initially set it up, I didn’t get any errors. So I’m not sure if anything changed with one of the latest updates, and I don’t know how to fix it as I’m not an advanced user.
Can you please help me with finding a way to fix it?
Screenshots of errors and ext storage setup:
I didn’t change anything for years, so I don’t know how to replicate the problem.
Example of webdav error:
{"reqId":"VMJmpIQax4qOkM0RDnHb","level":3,"time":"2025-04-25T21:23:28+00:00","remoteAddr":"172.68.27.103","user":"imds","app":"webdav","method":"PROPFIND","url":"/remote.php/dav/files/imds/Backups/MENU%20Laptop%20Backup/%23MENU%20Laptop%20Backup/Pictures/Viktor%20i%20Mijat%201.%20Rodjendan%202023","message":"Directory listing failed","userAgent":"Mozilla/5.0 (Windows) mirall/3.16.3 (build 20250416) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"31.0.4.1","exception":{"Exception":"Sabre\\DAV\\Exception\\ServiceUnavailable","Message":"Directory listing failed","Code":0,"Trace":[{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Tree.php","line":95,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":971,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":1664,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":1649,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":49,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Server.php","line":398,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":21,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/app/www/public/remote.php","line":145,"args":["/config/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/config/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":185,"Previous":{"Exception":"OCP\\Files\\StorageNotAvailableException","Message":"Directory listing failed","Code":1,"Trace":[{"file":"/app/www/public/lib/private/Files/Storage/Wrapper/PermissionsMask.php","line":131,"function":"getDirectoryContent","class":"OC\\Files\\Storage\\Common","type":"->"},{"function":"getDirectoryContent","class":"OC\\Files\\Storage\\Wrapper\\PermissionsMask","type":"->"},{"file":"/app/www/public/lib/private/Files/Cache/Scanner.php","line":457,"function":"iterator_to_array"},{"file":"/app/www/public/lib/private/Files/Cache/Scanner.php","line":414,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/app/www/public/lib/private/Files/Cache/Scanner.php","line":323,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/app/www/public/lib/private/Files/View.php","line":1386,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/app/www/public/lib/private/Files/View.php","line":1422,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":183,"function":"getFileInfo","class":"OC\\Files\\View","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Tree.php","line":95,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":971,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":1664,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":1649,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/app/www/public/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/app/www/public/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Connector/Sabre/Server.php","line":49,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/lib/Server.php","line":398,"function":"start","class":"OCA\\DAV\\Connector\\Sabre\\Server","type":"->"},{"file":"/config/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":21,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/app/www/public/remote.php","line":145,"args":["/config/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/app/www/public/lib/private/Files/Storage/Common.php","Line":752,"Hint":"Storage is temporarily not available"},"message":"Directory listing failed","exception":[],"CustomMessage":"Directory listing failed"},"id":"680bfd58d58ef"}
Example of permissions error:
{"reqId":"ftZ2lTJK1769lRNOUKud","level":3,"time":"2025-04-25T21:24:28+00:00","remoteAddr":"172.70.94.2","user":"imds","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/imds/Backups/MENU%20Laptop%20Backup/%23MENU%20Laptop%20Backup/Pictures/TP%20Link%20AX50","message":"opendir(/ext_backups/MENU Laptop Backup/#MENU Laptop Backup/Pictures/TP Link AX50): Failed to open directory: Permission denied at /app/www/public/lib/private/Files/Storage/Local.php#130","userAgent":"Mozilla/5.0 (Windows) mirall/3.16.3 (build 20250416) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"31.0.4.1","data":{"app":"PHP"},"id":"680bfd8f02589"}
I don't think it is
I don't think this matters
"192.168.0.9:444",
"drive.sveserver.com"
"dbtype": "mysql",
"version": "31.0.4.1",
"overwrite.cli.url": "https:\/\/drive.sveserver.com\/",
"overwritehost": "drive.sveserver.com",
"overwriteprotocol": "https",
"default_phone_region": "RS",
"dbport": "",
"mysql.utf8mb4": true,
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"mail_smtpauthtype": "LOGIN",
"mail_smtpsecure": "tls",
"theme": "",
"loglevel": 2,
"filelocking.enabled": "true",
"memcache.locking": "\\OC\\Memcache\\APCu",
"upgrade.disable-web": true,
"maintenance_window_start": 6
- activity: 4.0.0
- app_api: 5.0.2
- bruteforcesettings: 4.0.0
- circles: 31.0.0
- comments: 1.21.0
- contactsinteraction: 1.12.0
- dashboard: 7.11.0
- dav: 1.33.0
- federation: 1.21.0
- files: 2.3.1
- files_downloadlimit: 4.0.0
- files_external: 1.23.0
- files_pdfviewer: 4.0.0
- files_reminders: 1.4.0
- files_sharing: 1.23.1
- files_trashbin: 1.21.0
- files_versions: 1.24.0
- firstrunwizard: 4.0.0
- logreader: 4.0.0
- notifications: 4.0.0
- oauth2: 1.19.1
- password_policy: 3.0.0
- photos: 4.0.0-dev.1
- privacy: 3.0.0
- profile: 1.0.0
- provisioning_api: 1.21.0
- recommendations: 4.0.0
- related_resources: 2.0.0
- serverinfo: 3.0.0
- settings: 1.14.0
- sharebymail: 1.21.0
- support: 3.0.0
- survey_client: 3.0.0
- systemtags: 1.21.1
- text: 5.0.0
- theming: 2.6.1
- user_status: 1.11.0
- viewer: 4.0.0
- weather_status: 1.11.0
- webhook_listeners: 1.2.0
- workflowengine: 2.13.0
- admin_audit: 1.21.0
- encryption: 2.19.0
- files_rightclick: 1.6.0 (installed 1.6.0)
- maps: 1.5.0 (installed 1.3.1)
- onlyoffice: 9.8.0 (installed 9.8.0)
- richdocuments: 8.6.4 (installed 8.6.4)
- suspicious_login: 9.0.1
- unsplash: 3.0.3 (installed 2.2.1)
- updatenotification: 1.21.0 (installed 1.17.0)
- user_ldap: 1.22.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
