Since I’ve upgraded to Release 11 I suddenly face a non working webdav.
Working with some tools on windows / MacOS but not native on Windows 7 / Windows 10.
Access from a public ip is also impossible: Error 503 System in maintenance mode
: “app”:“webdav”,“message”:"Exception: {“Message”:“HTTP\/1.1 503 System in maintenance mode.”,“Exception”:“Sabre\\DAV\\Exception\\ServiceUnavailable”
Who know how to debug this please ?
Many thanks.
Nextcloud version : 11.0.2
Operating system : Centos 7 Linux version 3.10.0-514.el7.x86_64
nginx version : nginx/1.10.2
PHP version : PHP Version 7.0.15
Is this the first time you’ve seen this error and can you replicate it?: Yes first time
This error appears after upgrade from version 10
Unable to access webdav from Windows 10, perfectly working with MacOS Sierra/Mountain Duck and Windows 7 / winSCP but not in native mode (BasicAuthLevel=2).
Access from a public IP not working.
Fatal webdav Sabre\DAV\Exception\ServiceUnavailable: HTTP/1.1 503 System in maintenance mode.
[internal function] OCA\DAV\Connector\Sabre\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/usr/share/nginx/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/usr/share/nginx/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 466: Sabre\Event\EventEmitter->emit('beforeMethod', Array)
/usr/share/nginx/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/usr/share/nginx/html/nextcloud/apps/dav/appinfo/v1/webdav.php - line 60: Sabre\DAV\Server->exec()
/usr/share/nginx/html/nextcloud/remote.php - line 165: require_once('/usr/share/ngin...')
{main}
'instanceid' => 'instanceidislong',
'passwordsalt' => 'passwordsensitive',
'secret' => 'mysecretreplaced',
0 => 'webserver.ddns.net',
1 => '192.168.1.252',
'datadirectory' => '/nextcloud/data',
'overwrite.cli.url' => 'https://webserver.ddns.net',
'version' => '11.0.1.2',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'dbnxtuser',
'dbpassword' => 'thisisnotmypasswd',
'logtimezone' => 'UTC',
'mail_smtpmode' => 'php',
'mail_from_address' => 'email4domain',
'mail_domain' => 'DOMAIN.FR',
'mail_smtphost' => 'smtp.DOMAIN.FR',
'mail_smtpport' => '587',
'mail_smtpauth' => 1,
'loglevel' => 0,
'mail_smtpsecure' => 'ssl',
The output of your Apache/nginx/system log in `/var/log/____`:
access.log
192.168.1.13 - caroline [16/Feb/2017:17:08:38 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.10 - ben [16/Feb/2017:17:09:00 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.27 - - [16/Feb/2017:17:09:03 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 74 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.12; rv:51.0) Gecko/20100101 Firefox/51.0" "-"
192.168.1.13 - caroline [16/Feb/2017:17:11:09 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.10 - ben [16/Feb/2017:17:11:30 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.27 - - [16/Feb/2017:17:11:31 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 509 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.12; rv:51.0) Gecko/20100101 Firefox/51.0" "-"
192.168.1.13 - caroline [16/Feb/2017:17:11:39 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.10 - ben [16/Feb/2017:17:11:59 +0100] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 447 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.10 - ben [16/Feb/2017:17:12:00 +0100] "PROPFIND /remote.php/webdav/ HTTP/1.1" 207 420 "-" "Mozilla/5.0 (Windows) mirall/2.2.4 (build 2) (Nextcloud)" "-"
192.168.1.27 - - [16/Feb/2017:17:12:01 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 509 "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10.12; rv:51.0) Gecko/20100101 Firefox/51.0" "-"
