Hi folks,
some time ago I moved from OwnCloud to NextCloud, because updating OwnCloud most of the time ended up in crashing my installation. Unfortunately NextCloud doesn’t seem to do much better
Currently I’m running NextCloud 13.0.0 on my Debian 16.04 server.
Now I got a message (at the top right) that NextCloud 13.0.7 is available. By clicking the message I’m sent to the settings page and click “open updater”.
The following is shown at the updater page:
√ Initializing
Current version is 13.0.0.
Update to Nextcloud **14.0.3** !? available. (channel: "stable")
Following file will be downloaded automatically: https://download.nextcloud.com/server/releases/nextcloud-14.0.3.zip
√ Check for expected files
√ Check for write permissions
√ Enable maintenance mode
√ Create backup
√ Downloading
√ Verifying integrity
√ Extracting
√ Replace entry points
√ Delete old files
√ Move new files in place
√ Keep maintenance mode active?
√ Done
When I click “Continue Update” a new button appears at the bottom of the page stating: “Go back to your Nextcloud instance to finish the update”
When I click that button I’m sent back to the NextCloud start page with the message at the top that there’s an update available to NextCloud 13.0.7.
The error logs says:
Error PHP Zend OPcache can't be temporary enabled (it may be only disabled till the end of request) at Unknown#0
I don’t have PHP-Memory-Cache configured. Is that a problem?
The output of my config.php file in /path/to/nextcloud
'instanceid' => 'oclz2x6dbk6h',
'passwordsalt' => 'XXXX',
'secret' => 'XXXX',
0 => 'nc.XXXX.de',
'datadirectory' => '...../nextcloud/data',
'overwrite.cli.url' => 'XXXXX',
'dbtype' => 'sqlite3',
'version' => '13.0.0.14',
'logtimezone' => 'UTC',
'loglevel' => 2,
'theme' => '',
'updater.secret' => 'XXXXXX',
Besides of the missing Zend OPcache: Why are there so many version numbers? The updater says 13.0.7, config.php says ‘version’ => ‘13.0.0.14’ and the updater wants to 14.0.3
When I enter the updater page I get the following message in the Apache log:
AH01630: client denied by server configuration: /var/www/vhosts/XXXX.de/nextcloud/data/.ocdata
For testing purposes I set nextcloud/data and nextcloud/data/.ocdata to worls read-writable with no avail.
The .htaccess file in the data directory looks like this:
# Generated by Nextcloud on 2018-02-28 14:29:48
# line below if for Apache 2.4
<ifModule mod_authz_core.c>
Require all denied
</ifModule>
# line below if for Apache 2.2
<ifModule !mod_authz_core.c>
deny from all
Satisfy All
</ifModule>
# section for Apache 2.2 and 2.4
<ifModule mod_autoindex.c>
IndexIgnore *
</ifModule>
What can I do?
Is there a save way to export all the data, delete and set up Nextcloud completely new and import the data again?
