Nextcloud version (eg, 20.0.5): 23.0.1
Operating system and version (eg, Ubuntu 20.04): docker:23
Apache or nginx version (eg, Apache 2.4.25): apache
I Just moved my long running instance to docker and also updated from ~19 to 23. All in all it runs a lot faster however:
When i type anything in the interface from time to time characters just get dismissed.
“this is my fine and totally sane sentence”
becomes
“this is my ine and totallysane sentence”
or 2cdn time (very slowly typed)
“ths is m finend totaly sanesententece”
So it happens quiet randomly.
This is highly annoying and let to a lot of trouble (setting passwords…)
And, it happens in Firefox - but not in Midori…
In FF Console i see a lot of errors/warnings that look like this
Content Security Policy: Die Einstellungen der Seite haben das Laden einer Ressource auf inline blockiert ("script-src"). moz-extension:33:9
No OC found index.js:46:12
Proxying an event bus of version 2.1.1 with 1.3.0 index.es.js:2337:14
JQMIGRATE: Migrate is installed, version 3.3.2 jquery-migrate.min.js:2:708
jQuery is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. globals.js:62:15
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. globals.js:62:15
OCA.Comments.View initialized comments-app.js:32:8
jQuery is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 2 globals.js:62:15
Loading theming data for notification bell styling App.vue:138
Registering notifications container as a menu App.vue:148
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 2 globals.js:62:15
Notifications permissions granted App.vue:366
Polling interval updated to 30000 App.vue:326
Started background fetcher as session_keepalive is enabled App.vue:204
session heartbeat polling started session-heartbeat.js:101:9
Got notification data App.vue:289
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 5 globals.js:62:15
New notification, animating the bell icon App.vue:179
[DEBUG] unified-search: Unified Search initialized with the following providers
Object { 0: {…}, 1: {…}, 2: {…}, 3: {…}, 4: {…}, 5: {…}, 6: {…}, 7: {…}, 8: {…}, 9: {…}, … }
ConsoleLogger.js:29:16
About to call OCA.CloudsuiteGearsIntegration.App.initialize() in DOMContentLoaded event... app.js:35:11
initialize called in OCA.CloudsuiteGearsIntegration.App app.js:14:11
OCA.CloudsuiteGearsIntegration.App kickoffSignatureChecker() app.js:21:11
OCA.Files.fileList instance is invalid or not yet defined, can not refresh file list after signature request jobs finish! signature_request_checker.js:94:25
Starting signature job status notification checking loop. app.js:24:11
Start check loop for new signature job status notifications. signature_request_checker.js:102:21
start_time = 1645130488072 signature_request_checker.js:115:21
job_expiration_interval = 600 signature_request_checker.js:116:21
OCA.CloudsuiteGearsIntegration.App.initialize() has been called in DOMContentLoaded event. app.js:37:11
OCA.Files.fileActions instance is invalid or not yet defined, can not register custom file action! file_actions_integration.js:3:17
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 100 globals.js:62:15
Synchrone XMLHttpRequests am Haupt-Thread sollte nicht mehr verwendet werden, weil es nachteilige Effekte für das Erlebnis der Endbenutzer hat. Für weitere Hilfe siehe http://xhr.spec.whatwg.org/ jquery.js:9488:8
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 10 globals.js:62:15
No new notification data received App.vue:294
OC.Util.relativeModifiedDate is deprecated and will be removed in Nextcloud 21. See @nextcloud/moment 5 util.js:135:11
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 13 globals.js:62:15
$ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own. 12 globals.js:62:15
Uncaught TypeError: t.toolbar_div is undefined
D easymde.js:407
<anonymous> easymde.js:2007
es codemirror.js:7161
exports codemirror.js:7232
jo codemirror.js:6806
ns codemirror.js:7174
as codemirror.js:7202
is codemirror.js:7198
os codemirror.js:7229
us codemirror.js:7251
exports codemirror.js:3960
easymde.js:407:19
D easymde.js:407
easymde.js:407:19
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'XXX',
'version' => '23.0.0.10',
'dbname' => 'XXX',
'dbhost' => 'XXX',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'logtimezone' => 'UTC',
'loglevel' => 0,
'updatechecker' => false,
'theme' => '',
'instanceid' => 'XXX',
'overwrite.cli.url' => 'XXX',
'defaultapp' => 'files',
'app_install_overwrite' =>
0 => 'radio',
'trusted_proxies' =>
0 => 'XXX',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED_FOR',
'default_language' => 'de',
