Volume Configuration Not Persisted and Missing Apache Container in Nextcloud AIO on Synology DSM with Portainer
    • 11.7.0
    • Synology DSM 7.x
    • yes
    • Installation
    • AIO
I am experiencing issues with my Nextcloud AIO setup running on a Synology DSM system managed via Portainer. Below is my current docker-compose.yml configuration for the master container:
services:
    image: ghcr.io/nextcloud-releases/all-in-one:latest
    init: true
    restart: always
    volumes:
      - /volume2/docker/nextcloud/ncdata:/mnt/ncdata
    network_mode: bridge
    ports:
      - "8081:8080"
      - "11002:11000"
    environment:
      - APACHE_PORT=11000
      - APACHE_IP_BINDING=0.0.0.0
      - SKIP_DOMAIN_VALIDATION=true
volumes:
Issues:
  1. Volume Configuration Not Persisted:
    • Upon initial start, the nextcloud-aio-nextcloud container fails to start because the directory configuration for ncdata does not match that defined in the compose file.
      Volumes (on initial creation) of nextcloud-aio-nextcloud:
      Host/volume Path in container
      nextcloud_aio_nextcloud /var/www/html
      /mnt/ncdata* /mnt/ncdata
      *I’d expect /volume2/docker/nextcloud/ncdata here
    • When I manually change the volume configuration within the Nextcloud container to point to /volume2/docker/nextcloud/ncdata, it starts accordingly.
      It reverts back to the previous configuration (see table) upon container restart. This behavior disrupts the setup and prevents Nextcloud from accessing the correct data directory.
  2. Missing Apache Container:
    • The expected Apache container (nextcloud-aio-apache) does not exist in my current setup. It seems that this container is required for the Nextcloud AIO configuration to work correctly. It simply isn’t there.
Could someone please assist with resolving these issues? Are there any specific configurations or steps I need to follow to ensure the volume settings persist and the Apache container is created and correctly linked?
Thank you for your help.
  1. Deploy stack via compose (in portainer)
  2. Create containers (without any optional containers → all boxes unchecked)
  3. nextcloud container won’t start & apache containers isn’t there
nextcloud-aio-mastercontainer log (issue 1.)
Message: Could not start container nextcloud-aio-nextcloud: {"message":"Bind mount failed: '/mnt/ncdata' does not exist"}
Hi, please check GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
Thanks! It works now! I knew I was missing a small thing.
Here’s my updated compose (might help someone else):
services:
    init: true
    restart: always
    volumes:
    ports:
      - "8081:8080"
      - "11002:11000"
    environment:
      - APACHE_PORT=11000
      - NEXTCLOUD_DATADIR=/volume2/docker/nextcloud/ncdata
volumes:
