### ⚠️ Before submitting, please verify the following: ⚠️
- [x] This is a **bug…**, not a question or a configuration issue.
- [x] This issue is **not** already reported on Github (I've searched it).
- [x] Nextcloud Server and Desktop Client are **up to date**. See [Server Maintenance and Release Schedule](https://github.com/nextcloud/server/wiki/Maintenance-and-Release-Schedule) and [Desktop Releases](https://nextcloud.com/install/#install-clients) for supported versions.
- [x] I agree to follow Nextcloud's [Code of Conduct](https://nextcloud.com/contribute/code-of-conduct/)
### Bug description
I just downloaded from the website, check the file size and double click it to install.
I set all for default for the installation and then logged into my local Nextcloud server which has a self-signed certificate.Then to the fold syncing with, I choose 'jump'.
It all seemed natural, then I went to the Nextcloud icon in the menu bar. I saw my recent activities then came to the Virtual file settings, it told my `All Synced`.
But, when I try to access it in the Finder, it showed "Nextcloud is signed out" with an endlessly `Loading` icon.
The Nextcloud app seemed work well.
### Steps to reproduce
Install
Log in
Jump for wholly synced
### Expected behavior
Get access to my files.
### Which files are affected by this bug
All
### Operating system
macOS
### Which version of the operating system you are running.
macOS 15.1.1
### Package
Official macOS 12+ universal pkg
### Nextcloud Server version
1.4.15
### Nextcloud Desktop Client version
3.15.0-macos-vfs
### Is this bug present after an update or on a fresh install?
Fresh desktop client install
### Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
### Are you using an external user-backend?
- [x] Default internal user-backend
- [ ] LDAP/ Active Directory
- [ ] SSO - SAML
- [ ] Other
### Nextcloud Server logs
```shell
2024-12-08 21:10:35:943 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:571 ]: ssl errors "SSL-Errors happened for url \"https://192.168.2.107:30027/index.php/apps/theming/img/core/filetypes/application-pdf.svg\" \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The certificate is self-signed, and untrusted\" ( \"The certificate is self-signed, and untrusted\" ) \n "
2024-12-08 21:10:35:943 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:572 ]: QList(QSslCertificate(Version="3", SerialNumber="2c:8e:7a:fc", Digest="cFTJyIPzysbEXf/508q3WA==", Issuer="localhost", Subject="localhost", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, "localhost")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)))
2024-12-08 21:10:35:951 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:571 ]: ssl errors "SSL-Errors happened for url \"https://192.168.2.107:30027/apps/theming/img/core/filetypes/file.svg?v=af62e787\" \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The certificate is self-signed, and untrusted\" ( \"The certificate is self-signed, and untrusted\" ) \n "
2024-12-08 21:10:35:951 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:572 ]: QList(QSslCertificate(Version="3", SerialNumber="2c:8e:7a:fc", Digest="cFTJyIPzysbEXf/508q3WA==", Issuer="localhost", Subject="localhost", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, "localhost")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)))
2024-12-08 21:10:36:081 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:129 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:153 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:177 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:308 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:327 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:396 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:10:36:396 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/activity/api/v2/activity?previews=true&since=21649&limit=50&format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:10:36:841 [ info nextcloud.gui.updater /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/updater/sparkleupdater_mac.mm:305 ]: launching background check
2024-12-08 21:10:36:842 [ info nextcloud.gui.updater /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/updater/sparkleupdater_mac.mm:79 ]: Updater may check for updates: YES
2024-12-08 21:10:37:903 [ info nextcloud.gui.updater /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/updater/sparkleupdater_mac.mm:98 ]: "Finished loading appcast."
2024-12-08 21:10:37:904 [ info nextcloud.gui.updater /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/updater/sparkleupdater_mac.mm:98 ]: "No valid update found."
2024-12-08 21:10:49:726 [ info nextcloud.gui.macos.fileprovider.socketserver /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketserver.cpp:60 ]: New connection in file provider socket server
2024-12-08 21:10:49:727 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:212 ]: About to send account details to file provider extension "xxh@192.168.2.107:30027"
2024-12-08 21:11:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:11:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:11:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:11:04:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "8273c6e2-e557-4ad7-a4ca-4fbb2749c269"
2024-12-08 21:11:04:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:11:04:936 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:11:04:936 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:11:10:461 [ info nextcloud.gui.macos.fileprovider.socketserver /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketserver.cpp:60 ]: New connection in file provider socket server
2024-12-08 21:11:10:461 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:212 ]: About to send account details to file provider extension "xxh@192.168.2.107:30027"
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:734 ] [ OCC::Systray::computeWindowReferencePoint ]: screenRect: QRect(0,38 1512x944)
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:735 ] [ OCC::Systray::computeWindowReferencePoint ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:736 ] [ OCC::Systray::computeWindowReferencePoint ]: trayIconCenter: QPoint(948,18)
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:857 ] [ OCC::Systray::computeWindowPosition ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:858 ] [ OCC::Systray::computeWindowPosition ]: screenRect: QRect(0,0 1512x982)
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:859 ] [ OCC::Systray::computeWindowPosition ]: windowRect (reference) QRect(723,42 452x577)
2024-12-08 21:11:24:957 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:860 ] [ OCC::Systray::computeWindowPosition ]: windowRect (adjusted) QRect(723,42 452x577)
2024-12-08 21:11:24:972 [ warning default qrc:/qml/src/gui/tray/MainWindow.qml:99 ]: qrc:/qml/src/gui/tray/MainWindow.qml:99: ReferenceError: appsMenu is not defined
2024-12-08 21:11:24:972 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "de849e37-beb6-475d-a5cc-4c216956eb05"
2024-12-08 21:11:24:972 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:11:24:972 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json" has X-Request-ID "f74b69e9-e1cb-4563-a9fe-1dc62ac4df84"
2024-12-08 21:11:24:972 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v2.php/apps/notifications/api/v2/notifications" "OCC::ServerNotificationHandler"
2024-12-08 21:11:25:054 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:11:25:054 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:11:25:054 [ warning nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:993 ]: Nothing changed so nothing to retrieve - status code: 304
2024-12-08 21:11:25:054 [ info nextcloud.gui.servernotification /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/tray/notificationhandler.cpp:75 ]: Status code 304 Not Modified - No new notifications.
2024-12-08 21:11:25:054 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:11:31:359 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:43 ]: File provider socket disconnected
2024-12-08 21:11:31:360 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:50 ]: File provider socket object has been destroyed, destroying controller
2024-12-08 21:11:31:360 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:43 ]: File provider socket disconnected
2024-12-08 21:11:33:840 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "e6db004f-08c2-47de-8a06-008b86a0490d"
2024-12-08 21:11:33:840 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:11:33:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:11:33:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:11:33:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:11:33:907 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:11:33:907 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:11:34:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "619164b2-b7a0-4ae4-a7a3-57b5e05b36a0"
2024-12-08 21:11:34:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:11:34:937 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:11:34:937 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:11:35:840 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:565 ]: timer has not expired: do not check now 61180 62000
2024-12-08 21:11:35:840 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:591 ]: Skipping server availability check for account "xxh" with state 2
2024-12-08 21:11:47:294 [ info nextcloud.gui.macos.fileprovider.socketserver /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketserver.cpp:60 ]: New connection in file provider socket server
2024-12-08 21:11:47:295 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:212 ]: About to send account details to file provider extension "xxh@192.168.2.107:30027"
2024-12-08 21:12:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:12:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:12:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:12:04:840 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "128d6c86-1507-42aa-90b5-ccc974616d74"
2024-12-08 21:12:04:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:12:04:981 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:12:04:981 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:12:11:921 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:43 ]: File provider socket disconnected
2024-12-08 21:12:11:921 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:50 ]: File provider socket object has been destroyed, destroying controller
2024-12-08 21:12:33:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "9c7d0675-612a-426b-90fd-f06ac1ac4c71"
2024-12-08 21:12:33:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:12:33:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json" has X-Request-ID "70a1d10c-d613-4cc5-a620-7501c59b14d1"
2024-12-08 21:12:33:842 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v2.php/apps/notifications/api/v2/notifications" "OCC::ServerNotificationHandler"
2024-12-08 21:12:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:12:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:12:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:12:34:359 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:12:34:359 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:12:34:371 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:12:34:371 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:12:34:371 [ warning nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:993 ]: Nothing changed so nothing to retrieve - status code: 304
2024-12-08 21:12:34:371 [ info nextcloud.gui.servernotification /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/tray/notificationhandler.cpp:75 ]: Status code 304 Not Modified - No new notifications.
2024-12-08 21:12:34:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "c1cd4602-344f-4478-bdf8-e4a28b6f9e1b"
2024-12-08 21:12:34:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:12:34:949 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:12:34:949 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:12:37:841 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:285 ]: check connectivity
2024-12-08 21:12:37:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 6 "PROPFIND" "https://192.168.2.107:30027/remote.php/dav/files/xxh/" has X-Request-ID "e11d5c51-d411-4d5d-8605-0a4c2be6b6a3"
2024-12-08 21:12:37:841 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::PropfindJob created for "https://192.168.2.107" + "/" "OCC::ConnectionValidator"
2024-12-08 21:12:37:841 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:591 ]: Skipping server availability check for account "xxh" with state 2
2024-12-08 21:12:37:959 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:12:37:959 [ info nextcloud.sync.networkjob.propfind /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:658 ]: PROPFIND of QUrl("https://192.168.2.107:30027/remote.php/dav/files/xxh/") FINISHED WITH STATUS "OK"
2024-12-08 21:13:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:13:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:13:03:840 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:13:04:841 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "3732149d-ab24-4e8c-b21d-299b84d97a1c"
2024-12-08 21:13:04:842 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:13:04:966 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:04:966 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:10:863 [ info nextcloud.gui.macos.fileprovider.socketserver /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketserver.cpp:60 ]: New connection in file provider socket server
2024-12-08 21:13:10:865 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:212 ]: About to send account details to file provider extension "xxh@192.168.2.107:30027"
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:734 ] [ OCC::Systray::computeWindowReferencePoint ]: screenRect: QRect(0,38 1512x944)
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:735 ] [ OCC::Systray::computeWindowReferencePoint ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:736 ] [ OCC::Systray::computeWindowReferencePoint ]: trayIconCenter: QPoint(948,18)
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:857 ] [ OCC::Systray::computeWindowPosition ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:858 ] [ OCC::Systray::computeWindowPosition ]: screenRect: QRect(0,0 1512x982)
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:859 ] [ OCC::Systray::computeWindowPosition ]: windowRect (reference) QRect(723,42 452x577)
2024-12-08 21:13:31:716 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:860 ] [ OCC::Systray::computeWindowPosition ]: windowRect (adjusted) QRect(723,42 452x577)
2024-12-08 21:13:31:732 [ warning default qrc:/qml/src/gui/tray/MainWindow.qml:99 ]: qrc:/qml/src/gui/tray/MainWindow.qml:99: ReferenceError: appsMenu is not defined
2024-12-08 21:13:31:732 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "a3607e2b-458a-41f8-a5ae-ec38dafc8bc5"
2024-12-08 21:13:31:732 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:13:31:732 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json" has X-Request-ID "409cefd9-e567-4672-9686-37b3a0374959"
2024-12-08 21:13:31:732 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v2.php/apps/notifications/api/v2/notifications" "OCC::ServerNotificationHandler"
2024-12-08 21:13:31:789 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:31:789 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:31:801 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:31:801 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:31:801 [ warning nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:993 ]: Nothing changed so nothing to retrieve - status code: 304
2024-12-08 21:13:31:801 [ info nextcloud.gui.servernotification /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/tray/notificationhandler.cpp:75 ]: Status code 304 Not Modified - No new notifications.
2024-12-08 21:13:33:842 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "d81a5dce-3b63-4fd3-af27-5d1c0672110e"
2024-12-08 21:13:33:842 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:13:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:959 ]: Etag poll timer timeout
2024-12-08 21:13:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:963 ]: Folders to sync: 0
2024-12-08 21:13:33:842 [ info nextcloud.gui.folder.manager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/folderman.cpp:973 ]: Number of folders that don't use push notifications: 0
2024-12-08 21:13:33:901 [ warning nextcloud.sync.configfile /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/configfile.cpp:731 ]: Default update channel is "daily" because of the version suffix of the current client.
2024-12-08 21:13:33:913 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:33:913 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:33:923 [ warning nextcloud.sync.credentials.keychainchunk /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/creds/keychainchunk.cpp:360 ]: Unable to read "proxy-password" chunk "0" "Could not retrieve private key from keystore: The specified item could not be found in the keychain"
2024-12-08 21:13:33:932 [ info nextcloud.gui.macos.fileprovider.xpc /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileproviderxpc_mac.mm:210 ]: Checking if fast enumeration is enabled for extension "xxh@192.168.2.107:30027"
2024-12-08 21:13:33:932 [ warning nextcloud.gui.macos.fileprovider.xpc /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileproviderxpc_mac.mm:213 ]: Could not get service for extension "xxh@192.168.2.107:30027"
2024-12-08 21:13:33:932 [ warning default qrc:/qml/src/gui/tray/NCProgressBar.qml:25 ]: qrc:/qml/src/gui/tray/NCProgressBar.qml:25:17: QML QQuickRectangle: The current style does not support customization of this control (property: "background" item: QQuickRectangle(0x60000318f9c0, parent=0x0, geometry=0,0 0x0)). Please customize a non-native style (such as Basic, Fusion, Material, etc). For more information, see: https://doc.qt.io/qt-6/qtquickcontrols2-customize.html#customization-reference
2024-12-08 21:13:33:934 [ warning default qrc:/qml/src/gui/tray/NCProgressBar.qml:34 ]: qrc:/qml/src/gui/tray/NCProgressBar.qml:34:18: QML QQuickItem: The current style does not support customization of this control (property: "contentItem" item: QQuickItem(0x60000318d6c0, parent=0x0, geometry=0,0 0x0)). Please customize a non-native style (such as Basic, Fusion, Material, etc). For more information, see: https://doc.qt.io/qt-6/qtquickcontrols2-customize.html#customization-reference
2024-12-08 21:13:33:937 [ warning nextcloud.sync.credentials.keychainchunk /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/creds/keychainchunk.cpp:360 ]: Unable to read "proxy-password" chunk "0" "Could not retrieve private key from keystore: The specified item could not be found in the keychain"
2024-12-08 21:13:33:938 [ info nextcloud.sync.clientsideencryption /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/clientsideencryption.cpp:755 ]: Initializing
2024-12-08 21:13:33:938 [ info nextcloud.sync.clientsideencryption /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/clientsideencryption.cpp:757 ]: No Client side encryption available on server.
2024-12-08 21:13:33:938 [ info nextcloud.gui.account.settings /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountsettings.cpp:1362 ]: Account "xxh@192.168.2.107:30027" Client Side Encryption false
2024-12-08 21:13:33:939 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "013af2b0-d353-4167-a143-91ffcb1f00b5"
2024-12-08 21:13:33:939 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:13:33:939 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "87de5a79-610b-4103-abe6-39cdb2f2500b"
2024-12-08 21:13:33:948 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "deea5a68-c7e5-487a-9353-febd4439cddd"
2024-12-08 21:13:33:948 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:13:33:973 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:571 ]: ssl errors "SSL-Errors happened for url \"https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json\" \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n \tError in QSslCertificate(Version=\"3\", SerialNumber=\"2c:8e:7a:fc\", Digest=\"cFTJyIPzysbEXf/508q3WA==\", Issuer=\"localhost\", Subject=\"localhost\", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, \"localhost\")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)) : \"The certificate is self-signed, and untrusted\" ( \"The certificate is self-signed, and untrusted\" ) \n "
2024-12-08 21:13:33:973 [ info nextcloud.sync.account /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/account.cpp:572 ]: QList(QSslCertificate(Version="3", SerialNumber="2c:8e:7a:fc", Digest="cFTJyIPzysbEXf/508q3WA==", Issuer="localhost", Subject="localhost", AlternativeSubjectNames=QMultiMap((QSsl::DnsEntry, "localhost")), EffectiveDate=QDateTime(2024-08-11 05:59:44.000 UTC Qt::UTC), ExpiryDate=QDateTime(2025-09-12 05:59:44.000 UTC Qt::UTC)))
2024-12-08 21:13:34:058 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:34:058 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:34:059 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/remote.php/dav/avatars/xxh/128.png" has X-Request-ID "ec8a57aa-89ba-492d-b293-a5acf3193c13"
2024-12-08 21:13:34:059 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::AvatarJob created for "https://192.168.2.107" + "" "OCC::UserInfo"
2024-12-08 21:13:34:182 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:34:182 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:34:183 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/remote.php/dav/avatars/xxh/128.png" has X-Request-ID "989d5cb8-db38-4314-93f4-2fdde0de78cd"
2024-12-08 21:13:34:183 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::AvatarJob created for "https://192.168.2.107" + "" "OCC::UserInfo"
2024-12-08 21:13:34:198 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:34:278 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:34:842 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json" has X-Request-ID "049a54cf-3c71-4a3f-8943-ccfc0e9a4e00"
2024-12-08 21:13:34:842 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "ocs/v1.php/cloud/user" "OCC::UserInfo"
2024-12-08 21:13:34:952 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:34:952 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v1.php/cloud/user?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:734 ] [ OCC::Systray::computeWindowReferencePoint ]: screenRect: QRect(0,38 1512x944)
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:735 ] [ OCC::Systray::computeWindowReferencePoint ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:736 ] [ OCC::Systray::computeWindowReferencePoint ]: trayIconCenter: QPoint(948,18)
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:857 ] [ OCC::Systray::computeWindowPosition ]: taskbarScreenEdge: OCC::Systray::TaskBarPosition::Top
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:858 ] [ OCC::Systray::computeWindowPosition ]: screenRect: QRect(0,0 1512x982)
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:859 ] [ OCC::Systray::computeWindowPosition ]: windowRect (reference) QRect(723,42 452x577)
2024-12-08 21:13:35:756 [ debug nextcloud.gui.systray /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/systray.cpp:860 ] [ OCC::Systray::computeWindowPosition ]: windowRect (adjusted) QRect(723,42 452x577)
2024-12-08 21:13:35:765 [ warning default qrc:/qml/src/gui/tray/MainWindow.qml:99 ]: qrc:/qml/src/gui/tray/MainWindow.qml:99: ReferenceError: appsMenu is not defined
2024-12-08 21:13:35:765 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 2 "" "https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json" has X-Request-ID "e1506e52-8181-4484-bcd6-f8c19ca677d5"
2024-12-08 21:13:35:765 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::JsonApiJob created for "https://192.168.2.107" + "/ocs/v2.php/apps/user_status/api/v1/user_status" "OCC::UserStatusConnector"
2024-12-08 21:13:35:827 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:35:827 [ info nextcloud.sync.networkjob.jsonapi /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:972 ]: JsonApiJob of QUrl("https://192.168.2.107:30027/ocs/v2.php/apps/user_status/api/v1/user_status?format=json") FINISHED WITH STATUS "OK"
2024-12-08 21:13:35:923 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:43 ]: File provider socket disconnected
2024-12-08 21:13:35:923 [ info nextcloud.gui.macos.fileprovider.socketcontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersocketcontroller.cpp:50 ]: File provider socket object has been destroyed, destroying controller
2024-12-08 21:13:39:842 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:285 ]: check connectivity
2024-12-08 21:13:39:842 [ info nextcloud.sync.accessmanager /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/accessmanager.cpp:67 ]: 6 "PROPFIND" "https://192.168.2.107:30027/remote.php/dav/files/xxh/" has X-Request-ID "d8adb910-d07d-482f-b5a7-e14484085dc2"
2024-12-08 21:13:39:842 [ info nextcloud.sync.networkjob /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/abstractnetworkjob.cpp:365 ]: OCC::PropfindJob created for "https://192.168.2.107" + "/" "OCC::ConnectionValidator"
2024-12-08 21:13:39:842 [ info nextcloud.gui.account.state /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/accountstate.cpp:591 ]: Skipping server availability check for account "xxh" with state 2
2024-12-08 21:13:39:970 [ info nextcloud.sync.credentials.webflow /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/creds/webflowcredentials.cpp:405 ]: request finished
2024-12-08 21:13:39:970 [ info nextcloud.sync.networkjob.propfind /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/libsync/networkjobs.cpp:658 ]: PROPFIND of QUrl("https://192.168.2.107:30027/remote.php/dav/files/xxh/") FINISHED WITH STATUS "OK"
2024-12-08 21:13:44:554 [ info nextcloud.gui.mac.fileprovider.settingscontroller /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileprovidersettingscontroller_mac.mm:167 ]: Signalling file provider domain "xxh@192.168.2.107:30027"
2024-12-08 21:13:44:557 [ warning nextcloud.gui.macfileproviderutils /var/folders/yr/9dx0mtfj7kdf4725tmcz6md80000gp/T/macos-27019/src/gui/macOS/fileproviderutils_mac.mm:63 ]: No matching item domain for identifier "xxh@192.168.2.107:30027"
### Additional info
My user name is xxh and display name is Xu Xihe.
I have tried several times to reboot or uninstall&install fully, but nothing worked.
