Vertical view for Deck cards
In Trello card information is all in one vertical screen, with images in the description and also available in the discussion of a card. Being able to see this is much more efficient and means that we don’t miss things. Is this technically possible in NC Deck?
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
Deck doesn’t currently offer a Trello-style vertical card view with inline images and full descriptions visible at once, but it’s technically possible with UI changes. You can suggest this feature on the Deck GitHub repo. Meanwhile, you might consider using markdown to include images in the description and expand the card to view full content.
Thanks @hackito . I’ve had a look at the backlog too. It may be a limitation of NC, but using markdown to add images is just too slow. I need to be able to make a screenshot and drop it in the card.
