Hello folks, i don’t understand how to works versioning(even seeing the documentation) in Nextcloud and i would know if exists a way to configure the versioning in Nextcloud 12 for never exclude the versions…
Thanks to everyone.
Thanks to everyone.
What do you mean by “never exclude the versions”? You want to keep all versions?
To avoid any auto-deletion, you must set the variable in your config.php to disabled
Versions is a convenient way to get old versions of a file back. However, this is no mechanism I would rely on, always keep a backup (though it is harder to restore from).
