VALIDATION What is the minimum CPU requirement for NextCloud with Callobaro Online & FLOW
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
Hello community
I like to validate NextCloud on a VPS server but the requirements in the manual are not available which makes it very time consuming.
I would like to have a calculator with choosing the amount of user and the services.
But anyway, I like to know what minimum dimension needs a server for 5 user and Collabora Online and FLOW instances running.
If there is anybody who can support it will be most appreciated, thanks :slight_smile:
Kind regards
The Validator: Michael
It depends.
Your best bet is probably to make sure you meet minimum requirements in terms of memory/platform for installing via your chosen install method. Then doing some proof of concept validation.
There are numerous other variables such as storage that also have a impact.
That said, you can look around the forum and find all manner of deployments.
