Hello there,
I would like to share a very basic vagrant virtual box machine to have a ready to use installation of the new Nextcloud 15.0.0.
The objective of this box is to save time from manually installing nextcloud on a clean machine, for example for development purposes. Some time a developer is interested only in the development of a nextcloud app, but he spend a lot of minutes to setup a new machine.
The vagrant box is here: Vagrant box ale_polidori/Nextcloud v15.0.0 - Vagrant Cloud
and to have the virtual box machine ready to use, you have only to execute:
wget https://raw.githubusercontent.com/alepolidori/vagrant-files/master/nextcloud/nextcloud-15.0.0/Vagrantfile
vagrant up
After that you can login to nextcloud as admin, user1 and user2 with a default password as explained here.
The virtual machine is a NethServer linux distribution.
It could be useful for someone ?
Any comment or suggestion to improve are very welcome.
Thx.
