Hi!
I would like to use both apps, recognize and FaceRecognition side by side on the same instance. When tjinking about this two questions come to my mind and could not information in the docs:
Is this possible in principle, or are problems to be expected?
What does this mean for the “People” category in NC photos and memories?
Do you mind sharing how the results are in each? I’ve been looking to enable one or both of these with Memories, but facerecognitions pdlib and other requirements have turned into a MAJOR PITA to try to get in a NC container, and I saw Recognize ended support for NC 30 today and moved to 31 (WAY faster than I would normally move based on past hiccups).
Yes, that means: As part of version 9 you can no longer install on Nextcloud 30. v9 doesn’t support NC 30 anymore. But v8 still works fine. It’s a changelog, not an announcement.
