You could do it the other way arround. Create the calendars in the “main_user” account and share them from there with the relevant users who need access.
If you follow @bb77 suggestion to create the calendar in the main users account you could share the calendars via a POST-request with curl (you need the main users password though):
#!/usr/bin/env bash
set -euo pipefail
### begin variable declaration
# Nextcloud-URL (add subdirectory, if Nextcloud is not in webroot):
nextcloud_url="https://www.my_nextcloud.com/"
# username who shares the calendar:
user="USERNAME"
user_password="PASSWORD"
# name of the calendar to be shared:
calendar_name="CALENDARNAME"
# username with whom the calendar will be shared:
sharee="SHAREE"
# calendar access privileges for the sharee ("read-write" or "read")
sharee_access="read-write"
### end of variable declaration
# create URL to calendar (set together with variables declared before):
calendar_url="${nextcloud_url%%/}/remote.php/dav/calendars/${user}/${calendar_name}/"
# prepare data for POST request:
data='
<x4:share xmlns:x4="http://owncloud.org/ns">
<x4:set>
<x0:href xmlns:x0="DAV:">principal:principals/users/'${sharee}'</x0:href>
<x4:'${sharee_access}'/>
</x4:set>
</x4:share>'
# POST request to share the calendar $calendar from $user with $sharee
curl -sS -f -k -u "${user}:${user_password}" -H "Content-Type: application/xml; charset=utf-8" -X POST "${calendar_url}" -d "${data}"
printf '%s\n' "${user}s' calendar '${calendar_name}' successfully shared with '${sharee}'."
exit 0
