This is a general description of my server etc.
Unraid ver: 6.8.1
Nextcloud ver: 18.0.0 (latest)
Hardware: ASUS R710 server
Nextcloud apps: none except default
Unraid dockers: radar, sonar, nzbget, plex,mariadb, netdate (all latest versions)
Unraid VM’s: none
Array: 24Tb (7 Tb used)
I have moved some files from another source to my admin user directory in Nextcloud. The files do not show in Nextcloud. There are no other users besides my admin user in Nextcloud.
I have searched and it appears that OCC is the solution using filescan.
I have all of the syntax and commands information.
I have 1 simple question, after searching all of the posts:
How do you invoke/install OCC on the server??
This is the most direct reference I have found:
Using the occ command
Nextcloud’s occ command (origins from “ownCloud Console”) is Nextcloud’s command-line interface. You can perform many common server operations with occ , such as installing and upgrading Nextcloud, manage users, encryption, passwords, LDAP setting, and more.
occ is in the nextcloud/ directory; for example /var/www/nextcloud on Ubuntu Linux. occ is a PHP script. You must run it as your HTTP user to ensure that the correct permissions are maintained on your Nextcloud files and directories.
https://docs.nextcloud.com/server/18/admin_manual/configuration_server/occ_command.html?
All of the posts show there are a lot of “useful” commands in OCC . It also says you have to login as http user in order to use it. Is that under Unraid terminal or Nextcloud console?? Is it my Unraid user or Nextcloud user.
But, none of them show you how to invoke and/or install OCC – I must be stupid or something but I just don’t see this discussed anywhere.
Is OCC included under Nextcloud 18? Do I have to install it?
Don’t know where else to look??? If you need more info let me know.
Thanks in advance
