Hi nextcloudies,
i’ am try to use fulltextsearch /elasticsearch with a external fulltextsearch node. Curl tells me
that everything is fine …
“name” : “”,
“cluster_name” : “elasticsearch”,
“cluster_uuid” : “LSpyel10TIaamdTbhDYmEg”,
“version” : {
“number” : “7.0.1”,
“build_flavor” : “default”,
“build_type” : “deb”,
“build_hash” : “e4efcb5”,
“build_date” : “2019-04-29T12:56:03.145736Z”,
“build_snapshot” : false,
“lucene_version” : “8.0.0”,
“minimum_wire_compatibility_version” : “6.7.0”,
“minimum_index_compatibility_version” : “6.0.0-beta1”
and php occ fulltextsearch:test tells me:
.Testing your current setup:
Creating mocked content provider. ok
Testing mocked provider: get indexable documents. (2 items) ok
Loading search platform. (Elasticsearch) ok
Testing search platform. ok
Locking process ok
Removing test. ok
Pausing 3 seconds 1 2 3 ok
Initializing index mapping. fail
In Connection.php line 615:
{“error”:{“root_cause”:[{“type”:“mapper_parsing_exception”,“reason”:“Root mapping definition has unsupported parameters: [standard : {dynamic=true, properties={owner={type=keyword}, groups={type=keyword}, circles={type=keyw
ord}, metatags={type=keyword}, source={type=keyword}, title={copy_to=combined, analyzer=keyword, term_vector=yes, type=text}, content={copy_to=combined, analyzer=analyzer, term_vector=yes, type=text}, users={type=keyword}, t
ags={type=keyword}, provider={type=keyword}, subtags={type=keyword}, links={type=keyword}, combined={analyzer=analyzer, term_vector=yes, type=text}, hash={type=keyword}}}]”}],“type”:“mapper_parsing_exception”,“reason”:“Faile
d to parse mapping [_doc]: Root mapping definition has unsupported parameters: [standard : {dynamic=true, properties={owner={type=keyword}, groups={type=keyword}, circles={type=keyword}, metatags={type=keyword}, source={typ
e=keyword}, title={copy_to=combined, analyzer=keyword, term_vector=yes, type=text}, content={copy_to=combined, analyzer=analyzer, term_vector=yes, type=text}, users={type=keyword}, tags={type=keyword}, provider={type=keyword
}, subtags={type=keyword}, links={type=keyword}, combined={analyzer=analyzer, term_vector=yes, type=text}, hash={type=keyword}}}]”,“caused_by”:{“type”:“mapper_parsing_exception”,“reason”:“Root mapping definition has unsuppor
ted parameters: [standard : {dynamic=true, properties={owner={type=keyword}, groups={type=keyword}, circles={type=keyword}, metatags={type=keyword}, source={type=keyword}, title={copy_to=combined, analyzer=keyword, term_vec
tor=yes, type=text}, content={copy_to=combined, analyzer=analyzer, term_vector=yes, type=text}, users={type=keyword}, tags={type=keyword}, provider={type=keyword}, subtags={type=keyword}, links={type=keyword}, combined={anal
yzer=analyzer, term_vector=yes, type=text}, hash={type=keyword}}}]”}},“status”:400}
If i try to start indexing, this appears:
Options:
Memory:
┌─ Indexing ────
│ Action:
│ Provider: Account:
│ Document:
│ Info:
│ Title:
│ Content size:
│ Chunk: /
│ Progress: /
┌─ Results ────
│ Result: 0/0
│ Index:
│ Status:
│ Message:
┌─ Errors ────
│ Error: 0/0
│ Index:
│ Exception:
│ Message:
x:first result ## c/v:prec/next result ## b:last result
f:first error ## h/j:prec/next error ## d:delete error ## l:last error
q:quit ## p:pause
(the same as above …)
Whats happened there? Is it possible to use a external elasticsearch node?
Thanks in advance.
