I have set up my new RPi 5 and it is smoothly running on NextCloudPi (NC 30). All needed features are installed, but as I opened up the Memories-App, I can only see these ugly beauties:
I did the following error-checks:
- nc-scan
- nc-previews
- nc-fix-permissions
- clear-php-opcache
- and of course several reboots ^^
All without any error-logs
Even shortly uploaded photos don’t appear other than with missing preview.
This is my ncp-report:
NextcloudPi diagnostics
Cannot load Zend OPcache - it was already loaded
NextcloudPi version v1.55.3
NextcloudPi image
OS Armbian-unofficial 24.8.2 Bookworm \l . 6.6.45-current-bcm2712 (aarch64)
automount yes
USB devices sda
datadir /media/myCloudDrive/ncdata
data in SD no
data filesystem ext2/ext3
data disk usage 1.9T/3.6T
rootfs usage 16G/118G
swapfile /dev/zram2
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 30.0.6.2
HTTPD service up
PHP service up
MariaDB service up
Redis service up
HPB service up
Postfix service up
Internet check ok
Public IPv4 ***REMOVED SENSITIVE VALUE***
Public IPv6 ***REMOVED SENSITIVE VALUE***
Port 80 open
Port 443 open
IP ***REMOVED SENSITIVE VALUE***
Gateway ***REMOVED SENSITIVE VALUE***
Interface end0
Certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
Uptime 1day
Nextcloud configuration
"trusted_domains": {
"0": "localhost",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"11": "spurgo.ddns.net",
"1": "192.168.1.105",
"12": "spurgo.hopto.org",
"20": "spurgo.ddns.net",
"22": "192.168.1.5",
"3": "nextcloudpi",
"": "nextcloudpi",
"21": "spurgo.hopto.org",
"14": "nextcloudpi"
"dbtype": "mysql",
"version": "30.0.6.2",
"overwrite.cli.url": "https:\/\/nextcloudpi\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/media\/myCloudDrive\/ncdata\/tmp",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 60,
"overwriteprotocol": "https",
"logfile": "\/media\/myCloudDrive\/ncdata\/nextcloud.log",
"loglevel": 0,
"log_type": "file",
"htaccess.RewriteBase": "\/",
"theme": "",
"has_rebuilt_cache": true,
"mail_sendmailmode": "smtp",
"mail_smtpport": "587",
"data-fingerprint": "23be0a22e30e10acfc7196faf02ff519",
"mail_smtpauth": 1,
"twofactor_enforced": "true",
"admin"
"twofactor_enforced_excluded_groups": [
"hirnformation",
"Bruchst\u00fccke"
"memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-aarch64-glibc",
"memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-aarch64",
"enabledPreviewProviders": [
"OC\\Preview\\TIFF",
"OC\\Preview\\Movie",
"OC\\Preview\\Imaginary"
"defaultapp": "",
"memories.gis_type": 1
HTTPd logs
[Sun Mar 09 19:28:46.859132 2025] [authz_host:error] [pid 71611:tid 71633] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /js/ncp.js failed, reason: unable to get the remote host name, referer: https://192.168.1.5:4443/
[Sun Mar 09 19:28:46.995753 2025] [authz_host:error] [pid 71611:tid 71631] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /js/minified.js failed, reason: unable to get the remote host name, referer: https://192.168.1.5:4443/
[Sun Mar 09 19:28:47.007686 2025] [authz_host:error] [pid 71611:tid 71625] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unable to get the remote host name
[Sun Mar 09 19:28:47.015895 2025] [authz_host:error] [pid 71611:tid 71633] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /js/ncp.js failed, reason: unable to get the remote host name, referer: https://192.168.1.5:4443/
[Sun Mar 09 19:28:47.018140 2025] [authz_host:error] [pid 71611:tid 71628] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 19:29:03.444182 2025] [authz_host:error] [pid 71611:tid 71617] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 19:29:03.534718 2025] [authz_host:error] [pid 71611:tid 71617] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 19:29:07.694300 2025] [authz_host:error] [pid 71611:tid 71630] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 19:29:07.792450 2025] [authz_host:error] [pid 71611:tid 71630] [remote 192.168.1.55:55829] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Sun Mar 09 20:12:20.444401 2025] [authz_host:error] [pid 71622:tid 71647] [remote 192.168.1.55:56474] AH01753: access check of 'localhost' to /img/favicon.png failed, reason: unable to get the remote host name
[Mon Mar 10 06:51:08.776683 2025] [authnz_external:error] [pid 85286:tid 85292] [remote 192.168.1.119:50350] AuthExtern pwauth [/usr/sbin/pwauth]: Failed (1) for user ncp
[Mon Mar 10 06:51:08.777395 2025] [auth_basic:error] [pid 85286:tid 85292] [remote 192.168.1.119:50350] AH01617: user ncp: authentication failure for "/": Password Mismatch
[Mon Mar 10 07:18:24.115928 2025] [mpm_event:notice] [pid 71610:tid 71610] AH00493: SIGUSR1 received. Doing graceful restart
[Mon Mar 10 07:18:24.128626 2025] [ssl:warn] [pid 71610:tid 71610] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Mon Mar 10 07:18:24.135344 2025] [mpm_event:notice] [pid 71610:tid 71610] AH00489: Apache/2.4.62 (Debian) OpenSSL/3.0.15 configured -- resuming normal operations
[Mon Mar 10 07:18:24.135368 2025] [core:notice] [pid 71610:tid 71610] AH00094: Command line: '/usr/sbin/apache2'
[Tue Mar 11 12:23:05.610262 2025] [proxy_fcgi:error] [pid 175634:tid 175658] [remote 192.168.1.119:53376] AH01067: Failed to read FastCGI header
[Tue Mar 11 12:23:05.611094 2025] [proxy_fcgi:error] [pid 175634:tid 175658] (104)Connection reset by peer: [remote 192.168.1.119:53376] AH01075: Error dispatching request to :4443:
[Tue Mar 11 12:23:05.703171 2025] [proxy_fcgi:error] [pid 175634:tid 175652] [remote 192.168.1.119:53376] AH01067: Failed to read FastCGI header
[Tue Mar 11 12:23:05.703373 2025] [proxy_fcgi:error] [pid 175634:tid 175652] (104)Connection reset by peer: [remote 192.168.1.119:53376] AH01075: Error dispatching request to :4443:
Database logs
tail: cannot open '/var/log/mysql/*.log' for reading: No such file or directory
Nextcloud logs
{"reqId":"Z9AsfhdGLE1L_-8g-dsnVAAAAJI","level":0,"time":"2025-03-11T12:28:46+00:00","remoteAddr":"1.2.3.4","user":"--","app":"no app in context","method":"GET","url":"/index.php/apps/notify_push/test/remote","message":"OCA\\NotifyPush\\Controller\\TestController::remote uses the @NoCSRFRequired annotation and should use the #[OCP\\AppFramework\\Http\\Attribute\\NoCSRFRequired] attribute instead","userAgent":"--","version":"30.0.6.2","data":[]}
{"reqId":"KHggUrukZCcEQ4uzvuCk","level":0,"time":"2025-03-11T12:28:47+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"KHggUrukZCcEQ4uzvuCk","level":0,"time":"2025-03-11T12:28:47+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"H2ZnFQzvBYqZikfYF5AA","level":0,"time":"2025-03-11T12:28:47+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"H2ZnFQzvBYqZikfYF5AA","level":0,"time":"2025-03-11T12:28:47+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"jY2gYlBREbmnZrdf1hAv","level":0,"time":"2025-03-11T12:28:48+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"jY2gYlBREbmnZrdf1hAv","level":0,"time":"2025-03-11T12:28:48+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"oLaFAmM2COqwlpyKdvTq","level":0,"time":"2025-03-11T12:28:49+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"oLaFAmM2COqwlpyKdvTq","level":0,"time":"2025-03-11T12:28:49+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"J5FnnaCiVh7UJCNQ2Wu0","level":0,"time":"2025-03-11T12:28:50+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"J5FnnaCiVh7UJCNQ2Wu0","level":0,"time":"2025-03-11T12:28:50+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"LZ3PgOq7ovzLyhu6L7Kk","level":0,"time":"2025-03-11T12:28:50+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"LZ3PgOq7ovzLyhu6L7Kk","level":0,"time":"2025-03-11T12:28:50+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"e2OrmISTAahNdbfQMerp","level":0,"time":"2025-03-11T12:28:51+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"e2OrmISTAahNdbfQMerp","level":0,"time":"2025-03-11T12:28:51+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"cly5byygGk0XYiiXeYFa","level":0,"time":"2025-03-11T12:28:51+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"cly5byygGk0XYiiXeYFa","level":0,"time":"2025-03-11T12:28:51+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"Uo6S3sosKNiKQf5gPZrE","level":0,"time":"2025-03-11T12:28:52+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/Generate.php#252","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
{"reqId":"Uo6S3sosKNiKQf5gPZrE","level":0,"time":"2025-03-11T12:28:52+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"Using ${var} in strings is deprecated, use {$var} instead at /var/www/ncp-previewgenerator/ncp-previewgenerator-nc21/lib/Command/PreGenerate.php#214","userAgent":"--","version":"30.0.6.2","data":{"app":"PHP"}}
