Hello!
I switched my database setup, so I have an external database server running MariaDB with ssl enabled.
Now I moved the database from the old to the external server which is working fine, but after I do the setup for ssl on MariaDB I got an exception (see attached).
I can confirm I can connect with the login details provided with nextcloud on the ssh terminal.
I can also confirm that I worked for other systems like Wordpress and it worked if I remove the required SSL, so I’m sure that this is a nextcloud related thing.
And yes, I tried it also with the following code which you can find when you search for this problem:
’dbdriveroptions’ => array (
PDO::MYSQL_ATTR_SSL_KEY => ‘/etc/mysql/ssl/client-key.pem’,
PDO::MYSQL_ATTR_SSL_CERT => ‘/etc/mysql/ssl/client-cert.pem’,
PDO::MYSQL_ATTR_SSL_CA => ‘/etc/mysql/ssl/ca-cert.pem’,
Nextcloud version: 15.0.7
Operating system and version Debian 9.8
Apache or nginx version: nginx 1.15.11
PHP version (eg, 7.1): 7.3
2019/04/13 22:17:37 [error] 1498#1498: *5 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1045] Access denied for user 'nc_scharner_usr'@'IP_OF_DBSERVER' (using password: YES) in /var/www/nc-sch-prod/htdocs/lib/private/DB/Connection.php:64
Stack trace:
#0 /var/www/nc-sch-prod/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(448): OC\DB\Connection->connect()
#1 /var/www/nc-sch-prod/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(410): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/nc-sch-prod/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(354): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/nc-sch-prod/htdocs/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(710): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/nc-sch-prod/htdocs/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/nc-sch-p...PHP message: PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [1045] Access denied for user 'nc_scharner_usr'@'IP_OF_DBSERVER' (using password: YES) in /var/www/nc-sch-prod/htdocs/lib/private/DB/Connection.php:64
