I would like to go from a manual letsencrypt update process to using the ncp embedded one from the ncp admin page.
… but when clicking the “Apply” button I get the following:
- everything under /etc/letsencrypt/live gets deleted
- the apache nextcloud.conf and ncp.conf get the SSLCertificateFile and SSLCertificateKeyFile replaced from the letsencrypt files to the /etc/ssl/… files.
- the following message is displayed
[ letsencrypt ] (Tue Feb 8 18:41:01 CET 2022)
INFO: Metrics enabled: no
Apache self check:
AH00526: Syntax error on line 5 of /etc/apache2/sites-enabled/ncp.conf:
SSLCertificateFile: file ‘/etc/letsencrypt/live/sub.domain.com/fullchain.pem’ does not exist or is empty
Action ‘-t’ failed.
The Apache error log may have more information.
letsencrypt certificates disabled. Using self-signed certificates instead.
… which is weird because the fullchain.pem has been deleted by starting that process
Where and how do I need to tell ncp that letsencrypt should be used and not the self-signed certificates anymore?
… or do I not understand anything correctly?
Thank you,
kr,
Martin
