Hi everyone !
i would like to use Nextcloud as an easy Webdav endpoint and graphical interface to manage data from my app to a Azure storage blob container.
I understood that I can connect Nextcloud to Azure storage blob with a SMB connection, as an External storage but, when I go to the External storage panel, I’ve got this message :
“smbclient” n’est pas installé. Le montage de “SMB / CIFS”, “SMB / CIFS en utilisant les identifiants OC” n’est pas possible. Merci de demander à l’administrateur système de l’installer.
Which means that smbclient is not installed and need to be installed.
When I go to the marketplace, I cannot find the app, only the “SMB connection test” app.
So, first question, how can I make a SMB connection from nextcloud ?
And second question, does it have a more easier way to connect them ?
Nextcloud version (eg, 18.0.2): 19.0.1
Operating system and version (eg, Ubuntu 20.04): 18.04
Apache or nginx version (eg, Apache 2.4.25): ?
PHP version (eg, 7.1): 7.3.21
Deployement : Snap
Thank you very much !
Julien
