Nextcloud version (13.0.4) :
Operating system and version (Ubuntu 18.04) :
Apache version (Apache 2.4.29) :
PHP version (7.1.18) :
The output of `/var/www/html/nextcloud/config/config.php` :
'instanceid' => 'xx',
'passwordsalt' => 'xx',
'secret' => 'xx',
0 => '192.168.0.138',
'datadirectory' => '/var/www/html/nextcloud/data',
'overwrite.cli.url' => 'http://192.168.0.138/nextcloud',
'version' => '13.0.4.0',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xx',
'dbpassword' => 'xx',
The output of `/etc/apache2/sites-available/nextcloud.conf` :
<VirtualHost *:80>
ServerAdmin admin@example.com
DocumentRoot /var/www/html/nextcloud/
ServerName 192.168.0.138
ServerAlias 192.168.0.138
Alias /nextcloud "/var/www/html/nextcloud/"
<Directory /var/www/html/nextcloud/>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/html/nextcloud
SetEnv HTTP_HOME /var/www/html/nextcloud
</Directory>
</VirtualHost>
https://paste.debian.net/1045395/
The issue:
Quota does not work correctly.
- Create user in Nextcloud and give him 10mb quota
- Add this user to Nexcloud client app and add some big folder (more than 10mb). I added 3.8GB folder.
- The in NC client synchronization will be successful
- Go to NC interface, you will see files which is less than 10mb
- Go to your server when NC is installed and open users folder. You will see all this 3.8GB. You can use ncdu command
So all this 10mb quota is nothing ![]()
I have another instance with Nextcloud and issue is the same.
Please, fix it.
