Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version: 28.0.3 (docker image)
Operating system and version: Debian 12
Apache or nginx version: Apache 2.4.57
PHP version: 8.2.16
After successful authentication to Django based IDP provider, NextCloud displays the error “Access Forbidden, Failed to contact the OIDC provider token endpoint”
Error message seems to be reasonable because user_oidc sends to identity provider’s token endpoint GET request instead of POST and receives HTTP stastus 405 what finally causes the error I mentioned above.
As I don’t believe I’m the first person worldwide trying this kind of integration I think I must be wrong somewhere and am looking for some hints.
Is this the first time you’ve seen this error? : Y
- Install required components
- Configure OIDC client
- Start authentication process
This module has it's own configguration outside of the config.php (I think)
Thank you in advance.
