User Backend Using Raw SQL - Github Repo disappeared (404)
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
Does anybody know what happened to the the Github Repo and its owner?
https://github.com/PanCakeConnaisseur/user_backend_sql_raw/
404 page not found :frowning:
Greets
KoS
no idea what happened to the original repo.. may the author changed his nick. there is another one which looks same: GitHub - alexeyabel/user_backend_sql_raw: User management and authentication through arbitrary SQL queries for Nextcloud but it doesn’t really help as the app only supports nc29
thanks @wwe so it seems he “renamed” his github account :slight_smile:
it looks like it works even with nc31
