I am using Nextcloud since one year and now I have the project to split my home server into small entities.
The Idea is to let nextcloud (lts) on the server and use a mini server as entry (nginx) for all services accross the house (Plex, grafana, web apps,…). The Big server will go to sleep mode when not use and will be wake UP by the small one. The reason of it, IS to not use apps which do not need to run 24/24 and Split which need it to small one (nginx, home assistant, socket io,…) Until now no issue, but I am facing an issue with nextcloud.
My NC is using php-fpm socket to run, which was easy to point directly with nginx and fast-cgi. But it is another discussion when using a nginx on another server to point to it.
I have searched on Google and I have try many solutions :
change php-fpm port to listen to 127.0.0.1:9000 => looks like nginx return a 404
try to migrate to docker, but in this case I am not able to link my différents HDD mounted on the Root : /md0 and /md127
I Can share the docker-compose done, but in any case if someone have already done it or has a better solution let me know.
instead of setting php-fpm up to listen on a local socket, just set it up to listen on a TCP socket with a dedicated port, and point to the IP of the PHP-FPM server IP and the designated port in your new NGINX box. Besides changing from local socket in NGINX config, just copy ALL other NGINX config for your nextcloud site to the new NGINX. Stop NGINX on the PHP-FPM server and test. If it works, you can now delete NGINX on the local PHP-FPM server entirely.
Other solution is to leave the nextcloud box as-is and instead use the NGINX on your new tiny server, as reverseproxy to your Nextcloud. This solution is by far, the easiest, but with most overhead.
upstream php-handler {
server **.**.**.**:9001;
#server unix:/var/run/php/php7.4-fpm.sock;
server {
listen 80;
listen [::]:80;
server_name ***.***.com www.***.***.com;
include snippets/authelia.conf;
# enforce https
return 301 https://$server_name:443$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
# Use Mozilla's guidelines for SSL/TLS settings
# https://mozilla.github.io/server-side-tls/ssl-config-generator/
# NOTE: some settings below might be redundant
ssl_certificate /etc/letsencrypt/live/***.***.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/***.***.com/privkey.pem; # managed by Certbot
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/nextcloud;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 $scheme://$host:$server_port/remote.php/dav;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject appli>
#pagespeed off;
location / {
rewrite ^ /index.php;
allow all;
log_not_found off;
access_log off;
gzip on;
gzip_vary on;
gzip_comp_level 4;
#pagespeed off;
location / {
It is the nginx file used on the different server, this is the configuration file for php-fpm :
listen = 1**.1**.0.**:9001
I have check if server is running
Result from distant server :
pain@tendo:~$ SCRIPT_NAME=/ping SCRIPT_FILENAME=/status REQUEST_METHOD=GET cgi-fcgi -bind -connect 1**.1**.0.**:9001/index.php
Primary script unknownStatus: 404 Not Found
Content-type: text/html; charset=UTF-8
File not found.
The connection is successfull so PHP-FPM is listening and NGINX connects. Something with your passing of PHP files. On PHP-FPM you would have to define the document root of the listener, and then on NGINX, you will have to comment block the document listener.
