Nextcloud version: 12.0.3
Operating system and version: Debian 9.2 „Stretch“
Apache or nginx version: nginx/1.10.3
PHP version: PHP 7.0.19-1
replicate the issue:
- install current debian
- install php
- install postgresql
- install nginx
- install Nextcloud 12.0.3
- log in to Nextcloud
- click the upload button on the web interface in the files section
The issue:
When clicking the upload button (+) in the files tab of the web interface nothing happens.
When clicking the upload button (+) in the gallery everything works fine. An upload menu pops up and files can be uploaded. This upload dialog seems to be missing in the files section.
Some further information about my setup:
Debian with nginx and postgresql.
The nginx config parameters are set as described in the manual (https://docs.nextcloud.com/server/12/admin_manual/installation/nginx.html#nextcloud-in-the-webroot-of-nginx) except that I use the socket connection for the php-handler (server unix:/run/php/php7.0-fpm.sock;) instead of ip.
I tried the following browsers: Firefox(Linux and MacOS), Chromium(Linux), Chrome(Linux and MacOS). No error is shown in the browser console.
None
My config.php:
‘datadirectory’ => ‘/var/www/nextcloud/data’,
‘dbtype’ => ‘pgsql’,
‘version’ => ‘12.0.3.3’,
‘dbname’ => ‘nextcloud’,
‘dbhost’ => ‘/var/run/postgresql’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘www-data’,
‘dbpassword’ => ‘’,
‘installed’ => true,
‘updater.release.channel’ => ‘stable’,
The owner of the nextcloud directory and files is www-data.
The output of nginx error.log:
access forbidden by rule, client: 10.0.2.2, server: localhost, request: "GET /data/.ocdata?t=1508944576957
Thank you for your help. Please let me know if you need further information.
