Nextcloud version (eg, 29.0.5): Nextcloud Hub 8 (29.0.4)
Operating system and version (eg, Ubuntu 24.04): ubuntu (server) 24.04
Apache or nginx version (eg, Apache 2.4.25): im using the 29.0.4-apache version of nextcloud
PHP version (eg, 8.3): 8.2.21 cli
upload and download speed
Is this the first time you’ve seen this error? (Y/N):N
- normal install of nextcloud through docker compose
- disable a bunch of apps and keep what i want, edit php and add cron jobs
- now upload or download through the browser
There are no errors except some minor temporary stuff which shouldnt be a probelm
Request does not pass strict cookie check
"Jul 27, 2024, 10:30:45 PM"
Error richdocuments
ConnectException
cURL error 28: Resolving timed out after 5000 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://###/hosting/discovery
Failed to fetch discovery: cURL error 28: Resolving timed out after 5000 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://###/hosting/discovery
"Jul 27, 2024, 9:55:15 PM"
Error richdocuments
ConnectException
Error richdocuments
ConnectException
cURL error 28: Resolving timed out after 5000 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://###/hosting/capabilities
Failed to fetch capabilities: cURL error 28: Resolving timed out after 5000 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://###/hosting/capabilities
"Jul 27, 2024, 9:55:09 PM"
Error richdocuments
ConnectException
Error PHP
dns_get_record(): A temporary server error occurred. at /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php#113
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'redis' =>
'host' => 'redis',
'password' => '###',
'port' => 6379,
'instanceid' => '###',
'passwordsalt' => '###',
'secret' => '###',
0 => '###',
1 => '###',
'version' => '29.0.4.1',
'overwrite.cli.url' => '###',
'dbname' => 'nextcloud',
'dbhost' => 'mariadb',
'dbuser' => 'nextcloud',
'dbpassword' => '###',
for some reason i cannot open these, when catting or nanoing it just loads forever. but there is only a access.log and a error.log aswell as a other-vhost-access.log
The exact same as i it was before, there are a few errors that is there because i have dabled with collabora a bit. nothing after that.
The thing and problem is that im not getting the near max speed i could and it is a bit too slow for not only my liking but my use case. the server has gigabit internett and is located in my home, the pc im uploading/downloading from has 500 mpbs, this should give me i would say a minimum of 50 mb/s if not more. i have tried Pydio, Seafile, owncloud and filebrowser and ONLY in filebrowser have i managed speeds over 50 mb/s there it is actully very fast. hardware is not a bottleneck. i get under 20 mb/s upload and 30 mb/s download. Chunk size change has not helped at all. im reverse proxying through ngnix proxy manager but even on public ip it is slow. only on local ip is it fast and then it is very fast.
Free download manager manages download speed exceding 60 mb/s.
i have heard of multiple people managing to saturate a gig internett on nextcloud, and btw a normal install not in docker does not help. Feel free to ask more questions if needed. Thank you.
