Recently pulled the latest docker image and am getting this error trying to update from the homescreen.
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: All tables already have the correct collation -> nothing to do
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
OC\DB\Exceptions\DbalException: An exception occurred while executing a query: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1018 Can't read dir of './nextcloud/' (errno: 13 "Permission denied")
I tried changing permissions, but no luck:
chown -R www-data:www-data /var/www/html/
chmod -R +rw /var/www/html/
I’m not sure where the ./nextcloud
dir is supposed to be and what permissions it needs.
docker-compose.yml
version: '2'
volumes:
nextcloud:
db:
services:
db:
image: mariadb
restart: always
volumes:
- /mnt/md0/nextclouddb:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=<pwd>
- MYSQL_PASSWORD=<pwd>
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
build: .
restart: always
ports:
- 8080:80
links:
- db
volumes:
- nextcloud:/var/www/html
environment:
- MYSQL_HOST=db
- NEXTCLOUD_OVERWRITEPROTOCOL=https
Dockerfile
FROM nextcloud
RUN apt update
RUN apt install ffmpeg imagemagick ghostscript -y
I have a feeling it’s because the external folder mnt/md0/nextclouddb
is owned by root.
