Upgrade to 18.0.3 fails and stays in maintenance mode
wondering if someone can help identify the problem i have with running the updater from v17.0.1 to 18.0.3
Im using the web updater and for the most part it seems to have worked and then errors out right at the end and leaves the install in Maintenance mode
the web logging shows:
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: All tables already have the correct collation -> nothing to do
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
Updating database schema
Updated database
Checking for update of app “accessibility” in appstore
Checked for update of app “accessibility” in appstore
Checking for update of app “activity” in appstore
Checked for update of app “activity” in appstore
Checking for update of app “admin_audit” in appstore
Checked for update of app “admin_audit” in appstore
Checking for update of app “apporder” in appstore
Checked for update of app “apporder” in appstore
Checking for update of app “audioplayer” in appstore
Checked for update of app “audioplayer” in appstore
Checking for update of app “camerarawpreviews” in appstore
Checked for update of app “camerarawpreviews” in appstore
Checking for update of app “cloud_federation_api” in appstore
Checked for update of app “cloud_federation_api” in appstore
Checking for update of app “comments” in appstore
Checked for update of app “comments” in appstore
Checking for update of app “contacts” in appstore
Checked for update of app “contacts” in appstore
Checking for update of app “dav” in appstore
Checked for update of app “dav” in appstore
Checking for update of app “encryption” in appstore
Checked for update of app “encryption” in appstore
Checking for update of app “event_update_notification” in appstore
Checked for update of app “event_update_notification” in appstore
Checking for update of app “extract” in appstore
Update app “extract” from appstore
Checked for update of app “extract” in appstore
Checking for update of app “federatedfilesharing” in appstore
Checked for update of app “federatedfilesharing” in appstore
Checking for update of app “federation” in appstore
Checked for update of app “federation” in appstore
Checking for update of app “files” in appstore
Checked for update of app “files” in appstore
Checking for update of app “files_antivirus” in appstore
Update app “files_antivirus” from appstore
Repair step: Cleanup cron task
Checked for update of app “files_antivirus” in appstore
Checking for update of app “files_external” in appstore
Checked for update of app “files_external” in appstore
Checking for update of app “files_markdown” in appstore
Checked for update of app “files_markdown” in appstore
Checking for update of app “files_pdfviewer” in appstore
Checked for update of app “files_pdfviewer” in appstore
Checking for update of app “files_rightclick” in appstore
Checked for update of app “files_rightclick” in appstore
Checking for update of app “files_sharing” in appstore
Checked for update of app “files_sharing” in appstore
Checking for update of app “files_trashbin” in appstore
Checked for update of app “files_trashbin” in appstore
Checking for update of app “files_versions” in appstore
Checked for update of app “files_versions” in appstore
Checking for update of app “files_videoplayer” in appstore
Checked for update of app “files_videoplayer” in appstore
Checking for update of app “firstrunwizard” in appstore
Checked for update of app “firstrunwizard” in appstore
Checking for update of app “groupquota” in appstore
Checked for update of app “groupquota” in appstore
Checking for update of app “logreader” in appstore
Checked for update of app “logreader” in appstore
Checking for update of app “lookup_server_connector” in appstore
Checked for update of app “lookup_server_connector” in appstore
Checking for update of app “mail” in appstore
Update app “mail” from appstore
Repair step: Purify and migrate collected mail addresses
[0 / 0]: Purify and migrate collected mail addresses
Repair step: Make Mail itinerary extractor executable
Repair step: Migrate Mail provisioning config from config.php to the database
Repair info: No old config found
Repair step: Create or update provisioned Mail accounts
Repair info: No Mail provisioning config set
Checked for update of app “mail” in appstore
Checking for update of app “music” in appstore
Update app “music” from appstore
Repair step: Drop any incompatible music database entries
Repair step: Remove any playlist files mistakenly added to music_tracks table
Repair step: Combine multi-disk albums and store disk numbers per track
Repair info: 0 tracks were updated with a disk number
Repair info: 0 tracks were assinged to new albums when combining multi-disk albums
Repair info: 0 obsolete album entries were removed from the database
Repair info: 0 albums were updated with new hashes
Repair info: 0 albums were rmeoved because merging them failed; these need to be rescanned by the user
Repair info: obsolete disk number field was nullified in 0 albums
Checked for update of app “music” in appstore
Checking for update of app “news” in appstore
Update app “news” from appstore
Repair step: Migrate binary status into separate boolean fields
Checked for update of app “news” in appstore
Checking for update of app “nextcloud_announcements” in appstore
Checked for update of app “nextcloud_announcements” in appstore
Checking for update of app “notes” in appstore
Update app “notes” from appstore
Checked for update of app “notes” in appstore
Checking for update of app “notifications” in appstore
Checked for update of app “notifications” in appstore
Checking for update of app “oauth2” in appstore
Checked for update of app “oauth2” in appstore
Checking for update of app “passman” in appstore
Checked for update of app “passman” in appstore
Checking for update of app “password_policy” in appstore
Checked for update of app “password_policy” in appstore
Checking for update of app “passwords” in appstore
Update app “passwords” from appstore
Repair step: Repair Passwords Database Objects
Repair info: Checking 0 tag revisions
[0 / 0]: Repair Passwords Database Objects
Repair info: Fixed 0 tag revisions
Repair info: Checking 0 folder revisions
Repair info: Fixed 0 folder revisions
Repair info: Checking 0 password revisions
Repair info: Fixed 0 password revisions
Repair info: Checking 0 tag models
Repair info: Fixed 0 tag models
Repair info: Checking 0 folder models
Repair info: Fixed 0 folder models
Repair info: Checking 0 password models
Repair info: Fixed 0 password models
Repair info: Checking 0 password tag relations
Repair info: Fixed 0 password tag relations
Checked for update of app “passwords” in appstore
Checking for update of app “phonetrack” in appstore
Update app “phonetrack” from appstore
Checked for update of app “phonetrack” in appstore
Checking for update of app “privacy” in appstore
Checked for update of app “privacy” in appstore
Checking for update of app “provisioning_api” in appstore
Checked for update of app “provisioning_api” in appstore
Checking for update of app “quicknotes” in appstore
Update app “quicknotes” from appstore
Checked for update of app “quicknotes” in appstore
Checking for update of app “recommendations” in appstore
Checked for update of app “recommendations” in appstore
Checking for update of app “serverinfo” in appstore
Checked for update of app “serverinfo” in appstore
Checking for update of app “settings” in appstore
Checked for update of app “settings” in appstore
Checking for update of app “sharebymail” in appstore
Checked for update of app “sharebymail” in appstore
Checking for update of app “sociallogin” in appstore
Update app “sociallogin” from appstore
Repair step: Separate user configured providers internal name and title. Also removes old unnecessary user config.
Repair step: Set default group in each provider
Checked for update of app “sociallogin” in appstore
Checking for update of app “support” in appstore
Checked for update of app “support” in appstore
Checking for update of app “survey_client” in appstore
Checked for update of app “survey_client” in appstore
Checking for update of app “systemtags” in appstore
Checked for update of app “systemtags” in appstore
Checking for update of app “tasks” in appstore
Update app “tasks” from appstore
Checked for update of app “tasks” in appstore
Checking for update of app “text” in appstore
Checked for update of app “text” in appstore
Checking for update of app “theming” in appstore
Checked for update of app “theming” in appstore
Checking for update of app “theming_customcss” in appstore
Checked for update of app “theming_customcss” in appstore
Checking for update of app “twofactor_backupcodes” in appstore
Checked for update of app “twofactor_backupcodes” in appstore
Checking for update of app “updatenotification” in appstore
Checked for update of app “updatenotification” in appstore
Checking for update of app “video_converter” in appstore
Update app “video_converter” from appstore
Checked for update of app “video_converter” in appstore
Checking for update of app “viewer” in appstore
Checked for update of app “viewer” in appstore
Checking for update of app “workflowengine” in appstore
Checked for update of app “workflowengine” in appstore
Repair step: Repair mime types
Repair step: Clean tags and favorites
Repair info: 0 tags of deleted users have been removed.
Repair info: 0 tags for delete files have been removed.
Repair info: 0 tag entries for deleted tags have been removed.
Repair info: 0 tags with no entries have been removed.
Repair step: Repair invalid shares
Repair step: Move .step file of updater to backup location
Repair info: .step file exists
Repair info: .step-previous-update removed
Repair info: .step file moved to .step-previous-update
Repair step: Fix potential broken mount points
Repair info: No mounts updated
Repair step: Add log rotate job
Repair step: Clear frontend caches
Repair info: Image cache cleared
An error occurred.
im not sure what i need to do to correct this. I have tried turning maintenance mode off and it returns to the start of the updater again.
My environment is Ubuntu 18.04 running php 7.3.16 with NginX
i am in the same problem.
If anyone can help me, I will be very grateful.
Can you run the occ command from command line? You have a lot of apps, perhaps the whole process takes too long. If that does not help, I’d try to disable a few apps, you have a lot of them. In this case, it updates the core first and then you can enable the apps later one by one. In case one apps causes the problem you know which one it was.
I have it installed in Xigmanas, how is it done?
From already thank you very much
oddly i left it for a while and have come back to it and set the config file from 640 to 644, set maintenance maode off in the config file and ran the installer again and this time it worked without any issue…
Your approach helps on same issue with 20.0.14 update too! Thanks! :slightly_smiling_face:
