Nextcloud version (eg, 20.0.5): 29.0.0
Operating system and version (eg, Ubuntu 20.04): Debian 11
Apache or nginx version (eg, Apache 2.4.25): nginx 1.18.0-6.1+deb11u3
PHP version (eg, 7.4): 8.1
Since the upgrade to v29 I am not able to use the right-click context menu in the files app anymore when I am a regular user. Besides that I am not able to open a folder anymore. instead it prompts to download a html file. that html file which is named like the folder which I (left)clicked contains just the following error message:
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client.
so I thought it might be something with my nginx config but when testing further I noticed that when I login as an admin everything is working as it should. the context menu appears and I can open folders just fine.
I checked all apps if there are any group limits set and removed any from all apps. Still the same. then I make my user admin and all directly works as it should. removing admin permissions and get the html download on left click and right click context menu is gone again.
- upgrade
- login + open files app
- right click a folder
nothing related
'instanceid' => 'REDACTED',
'passwordsalt' => 'REDACTED',
'datadirectory' => '/opt/cloud/data',
'version' => '29.0.0.19',
'theme' => '',
0 => 'REDACTED',
1 => 'REDACTED',
2 => 'REDACTED',
'share_folder' => '/Shared',
'dbname' => 'REDACTED_oc_db',
'dbhost' => '127.0.0.1:3306',
'dbuser' => 'oc_dbadm',
'dbpassword' => 'REDACTED',
'forcessl' => true,
'secret' => 'REDACTED',
'loglevel' => 0,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'batch',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpauth' => 1,
'mail_smtphost' => 'REDACTED',
'mail_smtpname' => 'REDACTED',
'mail_smtppassword' => 'REDACTED',
'mail_domain' => 'REDACTED.REDACTED',
'mail_smtpport' => '587',
'trashbin_retention_obligation' => 'auto',
'maintenance_window_start' => 2,
'overwrite.cli.url' => 'https://REDACTED',
'data-fingerprint' => 'REDACTED',
'app_install_overwrite' =>
0 => 'ojsxc',
1 => 'files_rightclick',
'memories.exiftool' => '/var/www/nextcloud/apps/memories/bin-ext/exiftool-amd64-glibc',
'memories.vod.path' => '/var/www/nextcloud/apps/memories/bin-ext/go-vod-amd64',
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\Image',
1 => 'OC\\Preview\\Movie',
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'memories.gis_type' => 1,
'memories.db.triggers.fcu' => true,
this is my nginx config (but I dont think that makes a difference between user accounts…):
upstream php-handler {
server unix:/var/run/php/php-fpm.sock;
# Set the `immutable` cache control options only for assets with a cache busting `v` argument
map $arg_v $asset_immutable {
default ", immutable";
server {
listen 80;
listen [::]:80;
server_name REDACTED;
# Enforce HTTPS
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/REDACTED/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/REDACTED/privkey.pem;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
# HSTS settings
# could take several months.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
# this requires >= nginx 1.7.5: add_header Strict-Transport-Security "max-age=15768001;" always;
add_header Strict-Transport-Security "max-age=15768001; includeSubDomains;";
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Pagespeed is not supported by Nextcloud, so if your server is built
# with the `ngx_pagespeed` module, uncomment this line to disable it.
#pagespeed off;
# HTTP response headers borrowed from Nextcloud `.htaccess`
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "noindex, nofollow" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/nextcloud;
# Set .mjs and .wasm MIME types
# Either include it in the default mime.types list
# and include that list explicitly or add the file extension
# only for Nextcloud like below:
include mime.types;
types {
text/javascript mjs;
application/wasm wasm;
# Specify how to handle directories -- specifying `/index.php$request_uri`
# here as the fallback means that Nginx always exhibits the desired behaviour
# when a client requests a path that corresponds to a directory that exists
# on the server. In particular, if that directory contains an index.php file,
# that file is correctly served; if it doesn't, then the request is passed to
# the front-end controller. This consistent behaviour means that we don't need
# to specify custom rules for certain paths (e.g. images and other assets,
# `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
# `try_files $uri $uri/ /index.php$request_uri`
# always provides the desired behaviour.
index index.php index.html /index.php$request_uri;
# Rule borrowed from `.htaccess` to handle Microsoft DAV clients
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Make a regex exception for `/.well-known` so that clients can still
# access it despite the existence of the regex rule
# `location ~ /(\.|autotest|...)` which would otherwise handle requests
# for `/.well-known`.
location ^~ /.well-known {
# The following 6 rules are borrowed from `.htaccess`
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
# Anything else is dynamically handled by Nextcloud
location ^~ /.well-known { return 301 /index.php$uri; }
try_files $uri $uri/ =404;
# Rules borrowed from `.htaccess` to hide certain paths from clients
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
# Ensure this block, which passes PHP files to the PHP process, is above the blocks
# which handle static assets (as seen below). If this block is not declared first,
# then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
# to the URI, resulting in a HTTP 500 error response.
location ~ \.php(?:$|/) {
# Required for legacy support
rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|ocs-provider\/.+|.+\/richdocumentscode(_arm64)?\/proxy) /index.php$request_uri;
#rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy) /index.php$request_uri;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
#location ~ \.(?:css|js|svg|gif)$ {
# try_files $uri /index.php$request_uri;
# access_log off; # Optional: Don't log access to assets
# Serve static files
location ~ \.(?:css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite|map|ogg|flac)$ {
expires 6M; # Cache-Control policy borrowed from `.htaccess`
add_header Cache-Control "public, max-age=15778463$asset_immutable";
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from `.htaccess`
location /remote {
return 301 /remote.php$request_uri;
location / {
try_files $uri $uri/ /index.php$request_uri;
last but not least:
of course I cannot open the webdav url behind a folder (e.g. https://REDACTED/remote.php/dav/files/REDACTED/Backup
will give the same error as above) but interestingly when I put the folder I want to open in the URI like:
https://REDACTED/apps/files/personal?dir=/Backup
then I am in that folder Backup without an issue… of course right click and opening subfolders within here still does not work then.
