Hi!
I use only CLI to update/upgrade. So, to upgrade from 19.0.5 to 20.0.2, I did (short version):
curl https://download.nextcloud.com/server/releases/nextcloud-"$NCv".tar.bz2
curl https://download.nextcloud.com/server/releases/nextcloud-"$NCv".tar.bz2.sha512
sha512sum -c nextcloud-"$NCv".tar.bz2.sha512
tar xv nextcloud-"$NCv".tar.bz2
occ upgrade
occ db:add-missing-primary-keys
occ app:update --all
In /admin/overview, I have an integrity check alert. I did what I read here code_signing The results are:
- index.php and version.php are ok
- integrity:check-app calendar shows:
- EXCEPTION:
- class: OC\IntegrityCheck\Exceptions\InvalidSignatureException
- message: Signature data not found.
- integrity:check shows a lot of EXTRA_FILE:
- systemtags
- EXTRA_FILE
- appinfo/app.php
- dav
- EXTRA_FILE
- appinfo/app.php
- federation
- EXTRA_FILE
- appinfo/app.php
- appinfo/database.xml
- workflowengine
- EXTRA_FILE
- appinfo/app.php
- twofactor_backupcodes
- EXTRA_FILE
- appinfo/app.php
- files_rightclick
- EXTRA_FILE
- appinfo/app.php
- privacy
- EXTRA_FILE
- js/chunks/3-779c9a1dd894d19ed27d.js.map
- js/chunks/1-779c9a1dd894d19ed27d.js.map
- js/chunks/6-779c9a1dd894d19ed27d.js
- js/chunks/8-47c5d586fda355004f68.js
- js/chunks/7-779c9a1dd894d19ed27d.js.map
- js/chunks/5-779c9a1dd894d19ed27d.js.map
- js/chunks/9-779c9a1dd894d19ed27d.js.map
- js/chunks/2-779c9a1dd894d19ed27d.js
- js/chunks/0-47c5d586fda355004f68.js
- js/chunks/7-47c5d586fda355004f68.js
- js/chunks/3-47c5d586fda355004f68.js
- js/chunks/5-47c5d586fda355004f68.js.map
- js/chunks/7-47c5d586fda355004f68.js.map
- js/chunks/1-47c5d586fda355004f68.js.map
- js/chunks/3-47c5d586fda355004f68.js.map
- js/chunks/9-47c5d586fda355004f68.js.map
- js/chunks/0-47c5d586fda355004f68.js.map
- js/chunks/2-47c5d586fda355004f68.js.map
- js/chunks/6-47c5d586fda355004f68.js.map
- js/chunks/8-47c5d586fda355004f68.js.map
- js/chunks/6-779c9a1dd894d19ed27d.js.map
- js/chunks/2-779c9a1dd894d19ed27d.js.map
- js/chunks/0-779c9a1dd894d19ed27d.js.map
- js/chunks/8-779c9a1dd894d19ed27d.js.map
- files_trashbin
- EXTRA_FILE
- appinfo/app.php
- sharebymail
- EXTRA_FILE
- lib/Settings.php
- appinfo/app.php
- updatenotification
- EXTRA_FILE
- appinfo/app.php
- firstrunwizard
- EXTRA_FILE
- templates/wizard.php
- js/firstrunwizard.js.map
- appinfo/app.php
- survey_client
- EXTRA_FILE
- appinfo/install.php
- appinfo/app.php
- lookup_server_connector
- EXTRA_FILE
- appinfo/app.php
- settings
- EXTRA_FILE
- templates/certificates.php
- lib/Controller/CertificateController.php
- js/vue-vendors-settings-apps-07a08ab06887ac4d3cda.js.map
- js/vue-settings-users-7082413c9dfc951ccad2.js.map
- js/vue-vendors-settings-users-d5514d74b5ffc0988e86.js
- js/vue-vendors-settings-apps-settings-users-d63620712026bba06761.js.map
- js/vue-vendors-settings-users-b616c83b419bad59a286.js.map
- js/vue-vendors-settings-apps-b485bf14b5591afca5b0.js.map
- js/vue-settings-users-766ad7f732a2dec7aa8f.js
- js/vue-vendors-settings-apps-81109a8341a2c32d4e00.js.map
- js/vue-vendors-settings-users-d5514d74b5ffc0988e86.js.map
- js/vue-settings-apps-b6cb14668b3a8585d58f.js
- js/vue-vendors-settings-apps-settings-users-c1ebdb77d170f0ff93ee.js.map
- js/vue-settings-apps-b6cb14668b3a8585d58f.js.map
- js/vue-settings-users-766ad7f732a2dec7aa8f.js.map
- js/certificates.js
- files_versions
- EXTRA_FILE
- appinfo/app.php
- files_videoplayer
- EXTRA_FILE
- appinfo/app.php
- password_policy
- EXTRA_FILE
- appinfo/app.php
- federatedfilesharing
- EXTRA_FILE
- appinfo/app.php
- lib/ocm/CloudFederationProviderFiles.php
- cloud_federation_api
- EXTRA_FILE
- appinfo/app.php
- provisioning_api
- EXTRA_FILE
- lib/FederatedFileSharingFactory.php
- logreader
- EXTRA_FILE
- appinfo/app.php
- support
- EXTRA_FILE
- appinfo/app.php
- accessibility
- EXTRA_FILE
- appinfo/app.php
- files_external
- EXTRA_FILE
- lib/config.php
- files
- EXTRA_FILE
- appinfo/app.php
- lib/Activity/Settings/FileRestored.php
- lib/Activity/Settings/FileCreated.php
- lib/Activity/Settings/FileFavorite.php
- lib/Activity/Settings/FileDeleted.php
- js/search.js
- user_ldap
- EXTRA_FILE
- appinfo/app.php
- activity
- EXTRA_FILE
- lib/Controller/Activities.php
- lib/Controller/RemoteActivity.php
- lib/Controller/APIv1.php
- lib/Controller/APIv2.php
- lib/Controller/Feed.php
- lib/Controller/Settings.php
- appinfo/app.php
- nextcloud_announcements
- EXTRA_FILE
- appinfo/app.php
- comments
- EXTRA_FILE
- lib/Search/Provider.php
- appinfo/app.php
- serverinfo
- EXTRA_FILE
- appinfo/app.php
- files_pdfviewer
- EXTRA_FILE
- js/workersrc.js
- js/previewplugin.js
- vendor/pdfjs/build/pdf.worker.js.map
- vendor/pdfjs/build/pdf.js
- vendor/pdfjs/build/pdf.js.map
- vendor/pdfjs/web/locale/kok/viewer.properties
- vendor/pdfjs/web/locale/ak/viewer.properties
- vendor/pdfjs/web/locale/fr/viewer.properties
- vendor/pdfjs/web/locale/ta-LK/viewer.properties
- vendor/pdfjs/web/locale/lg/viewer.properties
- vendor/pdfjs/web/locale/en-ZA/viewer.properties
- vendor/pdfjs/web/locale/mai/viewer.properties
- vendor/pdfjs/web/locale/ia/viewer.properties
- vendor/pdfjs/web/locale/cak/viewer.properties
- vendor/pdfjs/web/locale/zh-CN/viewer.properties
- vendor/pdfjs/web/locale/nl/viewer.properties
- vendor/pdfjs/web/locale/mn/viewer.properties
- vendor/pdfjs/web/locale/bn-IN/viewer.properties
- vendor/pdfjs/web/locale/zam/viewer.properties
- vendor/pdfjs/web/locale/cs/viewer.properties
- vendor/pdfjs/web/locale/cy/viewer.properties
- vendor/pdfjs/web/locale/nn-NO/viewer.properties
- vendor/pdfjs/web/locale/fy-NL/viewer.properties
- vendor/pdfjs/web/locale/rw/viewer.properties
- vendor/pdfjs/web/locale/lt/viewer.properties
- vendor/pdfjs/web/locale/ks/viewer.properties
- vendor/pdfjs/web/locale/es-AR/viewer.properties
- vendor/pdfjs/web/locale/zh-TW/viewer.properties
- vendor/pdfjs/web/locale/ar/viewer.properties
- vendor/pdfjs/web/locale/tsz/viewer.properties
- vendor/pdfjs/web/locale/kab/viewer.properties
- vendor/pdfjs/web/locale/he/viewer.properties
- vendor/pdfjs/web/locale/es-ES/viewer.properties
- vendor/pdfjs/web/locale/hu/viewer.properties
- vendor/pdfjs/web/locale/or/viewer.properties
- vendor/pdfjs/web/locale/nso/viewer.properties
- vendor/pdfjs/web/locale/pl/viewer.properties
- vendor/pdfjs/web/locale/rm/viewer.properties
- vendor/pdfjs/web/locale/ast/viewer.properties
- vendor/pdfjs/web/locale/sv-SE/viewer.properties
- vendor/pdfjs/web/locale/lij/viewer.properties
- vendor/pdfjs/web/locale/en-CA/viewer.properties
- vendor/pdfjs/web/locale/sat/viewer.properties
- vendor/pdfjs/web/locale/et/viewer.properties
- vendor/pdfjs/web/locale/sw/viewer.properties
- vendor/pdfjs/web/locale/meh/viewer.properties
- vendor/pdfjs/web/locale/hr/viewer.properties
- vendor/pdfjs/web/locale/tn/viewer.properties
- vendor/pdfjs/web/locale/si/viewer.properties
- vendor/pdfjs/web/locale/sah/viewer.properties
- vendor/pdfjs/web/locale/be/viewer.properties
- vendor/pdfjs/web/locale/crh/viewer.properties
- vendor/pdfjs/web/locale/as/viewer.properties
- vendor/pdfjs/web/locale/tl/viewer.properties
- vendor/pdfjs/web/locale/sk/viewer.properties
- vendor/pdfjs/web/locale/pt-PT/viewer.properties
- vendor/pdfjs/web/locale/pt-BR/viewer.properties
- vendor/pdfjs/web/locale/oc/viewer.properties
- vendor/pdfjs/web/locale/locale.properties
- vendor/pdfjs/web/locale/tr/viewer.properties
- vendor/pdfjs/web/locale/da/viewer.properties
- vendor/pdfjs/web/locale/is/viewer.properties
- vendor/pdfjs/web/locale/es-CL/viewer.properties
- vendor/pdfjs/web/locale/hi-IN/viewer.properties
- vendor/pdfjs/web/locale/gn/viewer.properties
- vendor/pdfjs/web/locale/ro/viewer.properties
- vendor/pdfjs/web/locale/it/viewer.properties
- vendor/pdfjs/web/locale/ca/viewer.properties
- vendor/pdfjs/web/locale/en-US/viewer.properties
- vendor/pdfjs/web/locale/sr/viewer.properties
- vendor/pdfjs/web/locale/sl/viewer.properties
- vendor/pdfjs/web/locale/pa-IN/viewer.properties
- vendor/pdfjs/web/locale/hy-AM/viewer.properties
- vendor/pdfjs/web/locale/eo/viewer.properties
- vendor/pdfjs/web/locale/ka/viewer.properties
- vendor/pdfjs/web/locale/kk/viewer.properties
- vendor/pdfjs/web/locale/ku/viewer.properties
- vendor/pdfjs/web/locale/nb-NO/viewer.properties
- vendor/pdfjs/web/locale/ko/viewer.properties
- vendor/pdfjs/web/locale/br/viewer.properties
- vendor/pdfjs/web/locale/eu/viewer.properties
- vendor/pdfjs/web/locale/brx/viewer.properties
- vendor/pdfjs/web/locale/fi/viewer.properties
- vendor/pdfjs/web/locale/zu/viewer.properties
- vendor/pdfjs/web/locale/az/viewer.properties
- vendor/pdfjs/web/locale/te/viewer.properties
- vendor/pdfjs/web/locale/id/viewer.properties
- vendor/pdfjs/web/locale/ur/viewer.properties
- vendor/pdfjs/web/locale/ru/viewer.properties
- vendor/pdfjs/web/locale/csb/viewer.properties
- vendor/pdfjs/web/locale/es-MX/viewer.properties
- vendor/pdfjs/web/locale/uk/viewer.properties
- vendor/pdfjs/web/locale/vi/viewer.properties
- vendor/pdfjs/web/locale/mr/viewer.properties
- vendor/pdfjs/web/locale/ja/viewer.properties
- vendor/pdfjs/web/locale/ml/viewer.properties
- vendor/pdfjs/web/locale/de/viewer.properties
- vendor/pdfjs/web/locale/th/viewer.properties
- vendor/pdfjs/web/locale/bn-BD/viewer.properties
- vendor/pdfjs/web/locale/sq/viewer.properties
- vendor/pdfjs/web/locale/hsb/viewer.properties
- vendor/pdfjs/web/locale/hto/viewer.properties
- vendor/pdfjs/web/locale/el/viewer.properties
- vendor/pdfjs/web/viewer.js.map
- vendor/pdfjs/web/debugger.js
- vendor/pdfjs/web/viewer.css
- appinfo/app.php
- recommendations
- EXTRA_FILE
- appinfo/app.php
- admin_audit
- EXTRA_FILE
- appinfo/app.php
- theming
- EXTRA_FILE
- appinfo/app.php
- notifications
- EXTRA_FILE
- appinfo/app.php
- js/notifications.js
- js/notifications.js.map
- contactsinteraction
- EXTRA_FILE
- appinfo/app.php
- photos
- EXTRA_FILE
- appinfo/app.php
- js/photos.9.js
- js/photos.8.js
- js/photos.2.js.map
- js/photos.0.js.map
- js/photos.6.js.map
- js/photos.9.js.map
- js/photos.4.js.map
- js/photos.7.js.map
- js/photos.4.js
- js/photos.5.js
- js/photos.js.map
- js/photos.5.js.map
- js/photos.8.js.map
- js/photos.7.js
- js/photos.6.js
- js/photos.2.js
- js/photos.js
- js/photos.1.js
- js/photos.1.js.map
- js/photos.0.js
- text
- EXTRA_FILE
- appinfo/app.php
- js/vendors~editor-rich~files-modal.js
- js/vendors~editor-rich~files-modal.js.map
- viewer
- EXTRA_FILE
- appinfo/app.php
- calendar
- EXCEPTION
- OC\IntegrityCheck\Exceptions\InvalidSignatureException
- Signature data not found.
- core
- EXTRA_FILE
- core/doc/user/_sources/index.rst.txt
- core/doc/user/_sources/userpreferences.rst.txt
- core/doc/user/_sources/external_storage/external_storage.rst.txt
- core/doc/user/_sources/external_storage/index.rst.txt
- core/doc/user/_sources/user_2fa.rst.txt
- core/doc/user/_sources/session_management.rst.txt
- core/doc/user/_sources/files/index.rst.txt
- core/doc/user/_sources/files/sharing.rst.txt
- core/doc/user/_sources/files/deleted_file_management.rst.txt
- core/doc/user/_sources/files/transfer_ownership.rst.txt
- core/doc/user/_sources/files/access_webdav.rst.txt
- core/doc/user/_sources/files/projects.rst.txt
- core/doc/user/_sources/files/encrypting_files.rst.txt
- core/doc/user/_sources/files/version_control.rst.txt
- core/doc/user/_sources/files/access_webgui.rst.txt
- core/doc/user/_sources/files/quota.rst.txt
- core/doc/user/_sources/files/file_drop.rst.txt
- core/doc/user/_sources/files/desktop_mobile_sync.rst.txt
- core/doc/user/_sources/files/large_file_upload.rst.txt
- core/doc/user/_sources/files/federated_cloud_sharing.rst.txt
- core/doc/user/_sources/pim/sync_ios.rst.txt
- core/doc/user/_sources/pim/sync_kde.rst.txt
- core/doc/user/_sources/pim/sync_osx.rst.txt
- core/doc/user/_sources/pim/contacts.rst.txt
- core/doc/user/_sources/pim/index.rst.txt
- core/doc/user/_sources/pim/sync_thunderbird.rst.txt
- core/doc/user/_sources/pim/calendar.rst.txt
- core/doc/user/_sources/pim/sync_gnome.rst.txt
- core/doc/user/_sources/pim/sync_windows10.rst.txt
- core/doc/user/_sources/pim/sync_android.rst.txt
- core/doc/user/_sources/webinterface.rst.txt
- core/doc/user/_sources/contents.rst.txt
- core/doc/user/_sources/whats_new.rst.txt
- core/search/css/results.scss
- core/search/js/searchprovider.js
- core/search/js/search.js
- core/js/systemtags/systemtagsmappingcollection.js
- core/js/systemtags/systemtagscollection.js
- core/js/systemtags/templates.js
- core/js/systemtags/systemtags.js
- core/js/systemtags/systemtagmodel.js
- core/js/systemtags/merged-systemtags.js
- core/js/systemtags/templates/result_form.handlebars
- core/js/systemtags/templates/result.handlebars
- core/js/systemtags/templates/selection.handlebars
- core/js/systemtags/systemtagsinputfield.js
- core/js/files/fileinfo.js
- core/js/files/client.js
- core/js/files/iedavclient.js
- 3rdparty/doctrine/dbal/lib/Doctrine/DBAL/README.markdown
- 3rdparty/doctrine/dbal/.appveyor.yml
- 3rdparty/doctrine/dbal/.scrutinizer.yml
- 3rdparty/doctrine/dbal/phpcs.xml.dist
- 3rdparty/doctrine/dbal/composer.lock
- 3rdparty/doctrine/cache/lib/Doctrine/Common/Cache/RiakCache.php
- 3rdparty/doctrine/cache/README.md
- 3rdparty/doctrine/cache/docs/en/index.rst
- 3rdparty/doctrine/event-manager/docs/en/reference/index.rst
- 3rdparty/doctrine/event-manager/docs/en/index.rst
Beside that, it seems to be working
Could somebody point me a docs page or explain how to correct it please?
Better… how to avoid this for next upgrades?
Best regards, and many thanks to all :))
