I’m running Nextcloud 13.0.6 on a VM. I would like to know if I need to upgrade it manually or if updater will tell me a new version is avalaible soon ?
My config :
Nextcloud version : 13.0.6
Operating system and version : Ubuntu 18.04.1 x64
Apache : 2.4.29
PHP version : 7.2.10
If the web updater does not offer the upgrade by now, you can try this: switch from stable to beta. Now the version 14.0.1 should be selectable. Do the upgrade and switch back to stable. Worked for me.
