Updates for Nextcloud Hub 25 Autumn & 26 Winter, right before our spring release
Originally published at: Updates for Nextcloud Hub 25 Autumn & 26 Winter, right before our spring release - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 25 Autumn or Nextcloud Hub 26 Winter, we strongly recommend you to update to version 32.0.10 and 33.0.4 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
Maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
  • Nextcloud Hub 25 Autumn (version 32.0.10)
  • Nextcloud Hub 26 Winter (version 33.0.4)
Join the Nextcloud Hub 26 Spring release!
Celebrating a decade of privacy, sovereignty and collaboration. Nextcloud Hub 26 Spring is launching live on June 9 at 2 PM CEST / 8 AM EDT. Don’t miss the livestream on YouTube or PeerTube – save your seat!
Watch the livestream
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
Please see Could not post message: Request failed with status code 500
and
https://github.com/nextcloud/notifications/issues/3035
when updating and especially if you’re using Talk.
