Nextcloud version (eg, 12.0.2): 12.0.3
Operating system and version (eg, Ubuntu 17.04): Ubuntu 17.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.18 (Ubuntu)
PHP version (eg, 7.1): 7.0.28
MySql: 5.7.22
Whenever I start the updater from the administartor panel It displays the remark: Initializing and it shows the version number: 12.0.3.
Nothing else happens and there is nothing in the logging.
Is this the first time you’ve seen this error? (Y/N): No
- Just press open updater from admin panel
PASTE HERE
NONE!
root@srv01:/var/www/nc/config# more config.php
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'xxx.nl',
'datadirectory' => '/xxx/',
'overwrite.cli.url' => 'http://xxx.nl', (https? http is not working...)
'version' => '12.0.3.3',
'dbname' => 'NextCloud',
'dbhost' => 'localhost',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'php',
'mail_from_address' => 'dpkweb.nl',
'mail_domain' => 'xxx',
'mail_smtphost' => 'xxx',
'mail_smtpport' => 'xxx',
'mail_smtpauth' => 1,
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxx',
'mail_smtpsecure' => 'ssl',
'updater.secret' => 'xxx',
