example
longer
example
here
Nextcloud version (eg, 18.0.2): 16.0.4
Operating system and version (eg, Ubuntu 20.04): CentOS Linux 7
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.6 (CentOS)
PHP version (eg, 7.1): 7.2.22
I am trying to update my Nextcloud installation via the automatic updater. The updater gives an error message
Check for expected files
The following extra files have been found:
.htefxjwncnszcr.data
This file appears to be a directory, which contains the user files and data, and it is listed as the data-directory in the config.php file. I did find very similar issues in the posts, but none allowed me to solve this issue. Can I just move the directory away, run the update and move the directory back?
In the index.php-file (shown below) there is no mention of the directory.
Thanks a lot for your time!!
Is this the first time you’ve seen this error? (Y/N): y
'instanceid' => 'xxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxx',
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
0 => 'localhost',
1 => '212.xxxxxxxx',
2 => 'www.xxxxx.de', ),
'datadirectory' => '/home/default/html/.htefxjwncnszcr.data',
'version' => '16.0.4.1',
'overwrite.cli.url' => 'http://xxxxxxxxxx',
'dbname' => 'default_ivug1',
'dbhost' => 'localhost',
'dbtableprefix' => 'oxpc_',
'dbuser' => 'default_ivug1',
'dbpassword' => 'xxxxxxxxxxxxxxxxxxx',
'mail_smtpmode' => 'smtp',
'ldapIgnoreNamingRules' => false,
'updater.secret' => '$xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
part of index.php
private function getExpectedElementsList() {
$expected = [
// Generic
// Folders
'.well-known',
'3rdparty',
'apps',
'config',
'core',
'data',
'l10n',
'lib',
'ocs',
'ocs-provider',
'ocm-provider',
'resources',
'settings',
'themes',
'updater',
// Files
'.rnd',
'index.html',
'indie.json',
'.user.ini',
'console.php',
'cron.php',
'index.php',
'public.php',
'remote.php',
'status.php',
'version.php',
'robots.txt',
'.htaccess',
'AUTHORS',
'CHANGELOG.md',
'COPYING',
'COPYING-AGPL',
'occ',
'db_structure.xml',
