example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.12
Operating system and version (eg, Ubuntu 20.04): Debian 10
Apache or nginx version (eg, Apache 2.4.25): nginx 1.14.2
PHP version (eg, 7.4): 7.4
I had not updated my nextcloud instance in a while (after all, everything was working fine), but I noticed I was like 4 major versions behind. So I decided to update, and updaing from 21 to 22 went fine. When I updated to 23 (using the online interface updater), I got a bunch of issues-- WebDAV is broken, can’t resolve ‘/nextcloud/ocs-provider’, cannot resolve webfinger/nodeinfo/caldav/carddav.
I don’t even care about updating anymore. It would be great to get this fixed, but if I cant, can someone see if they can help me revert to the previous working version?
EDIT: To clarify. I don’t know what is wrong. These are just the errors that the page is telling me. I went down a rabbit hole thinking it was an nginx issue for a while, but I have no idea anymore. If needed I can post the configuration, BUT it is literally the same as the example nginx one (besides for addresses) AND I wouldnt expect that to magically change or break over an update.
- uh. I updated from an old version, trying to update to the latest version.
Nextcloud Log
Info updater \OC\Updater::resetLogLevel: Reset log level to Warning(2) 2023-01-18T16:35:50-0500
Info updater \OC\Updater::maintenanceDisabled: Turned off maintenance mode 2023-01-18T16:35:50-0500
Info updater \OC\Updater::updateEnd: Update successful 2023-01-18T16:35:50-0500
Info updater \OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check 2023-01-18T16:35:50-0500
Info updater \OC\Updater::startCheckCodeIntegrity: Starting code integrity check... 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Add background job to set the lookup server share state for users 2023-01-18T16:35:22-0500
Info no app in context Deprecated event type for \OC\Repair::step: Symfony\Component\EventDispatcher\GenericEvent is used 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Repair DAV shares 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Queue a one-time job to check for user uploaded certificates 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Add job to cleanup the bruteforce entries 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Remove old dashboard app config data 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Check encryption key format 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Keep legacy encryption enabled 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Reset generated avatar flag 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Clear access cache of projects 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: No need to remove link shares. 2023-01-18T16:35:22-0500
Info no app in context Deprecated event type for \OC\Repair::info: Symfony\Component\EventDispatcher\GenericEvent is used 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Remove potentially over exposing share links 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Add background job to cleanup login flow v2 tokens 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Cleanup invalid photocache files for carddav 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Queue a one-time job to cleanup old backups of the updater 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Add preview background cleanup job 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Clear every generated avatar on major updates 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: JS cache cleared 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: SCSS cache cleared 2023-01-18T16:35:22-0500
Debug scss_cacher SCSSCacher::resetCache Locking removed 2023-01-18T16:35:22-0500
Debug scss_cacher SCSSCacher::resetCache css cache cleared! 2023-01-18T16:35:22-0500
Debug scss_cacher SCSSCacher::resetCache Lock acquired 2023-01-18T16:35:22-0500
Debug scss_cacher SCSSCacher::resetCache 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: Image cache cleared 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Clear frontend caches 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Add log rotate job 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Install new core bundle components 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Repair language codes 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: No mounts updated 2023-01-18T16:35:22-0500
Info updater \OC\Repair::step: Repair step: Fix potential broken mount points 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: Update the oauth2_clients table schema. 2023-01-18T16:35:22-0500
Info updater \OC\Repair::info: Repair info: Update the oauth2_access_tokens table schema. 2023-01-18T16:35:21-0500
Info no app in context Deprecated event type for \OC\Repair::info: Symfony\Component\EventDispatcher\GenericEvent is used 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Migrate oauth2_clients table to nextcloud schema 2023-01-18T16:35:21-0500
Info no app in context Deprecated event type for \OC\Repair::step: Symfony\Component\EventDispatcher\GenericEvent is used 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Add preview cleanup background jobs 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: Repair step already executed 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Add move avatar background job 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: .step file moved to .step-previous-update 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: .step-previous-update removed 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: .step file exists 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Move .step file of updater to backup location 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Repair invalid shares 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: 0 tags with no entries have been removed. 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: 0 tag entries for deleted tags have been removed. 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: 0 tags for delete files have been removed. 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: 0 tags of deleted users have been removed. 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Clean tags and favorites 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Repair mime types 2023-01-18T16:35:21-0500
Info updater \OC\Repair::info: Repair info: All tables already have the correct collation -> nothing to do 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Repair MySQL collation 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Create help command 2023-01-18T16:35:21-0500
Info updater \OC\Repair::step: Repair step: Cache the user display names
'instanceid' => 'myinstanceid',
'passwordsalt' => 'mypasswordsalt',
'secret' => 'mysecret',
0 => 'nextcloud.chadwilson.xyz',
'version' => '23.0.12.2',
'overwrite.cli.url' => 'https://my.url',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'myusername',
'dbpassword' => 'mypassword',
'updater.secret' => 'myupdatersecret',
'theme' => '',
'loglevel' => 2,
'defaultapp' => 'calendar',
nginx error log
2023/01/19 00:00:49 [error] 627#62Summary7: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/search/providers?from=%2Fnextcloud%2Fsettings%2Fadmin%2Foverview HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/search/providers?from=%2Fnextcloud%2Fsettings%2Fadmin%2Foverview HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PROPFIND /nextcloud/remote.php/webdav HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocm-provider/ HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocm-provider/ HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs-provider/ HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs-provider/ HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/settings/ajax/checksetup HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/settings/ajax/checksetup HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/heartbeat HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/heartbeat HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/index.php/.well-known/webfinger HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/index.php/.well-known/webfinger HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/index.php/.well-known/nodeinfo HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/index.php/.well-known/nodeinfo HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PROPFIND /nextcloud/remote.php/dav/ HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:00:59 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PROPFIND /nextcloud/remote.php/dav/ HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:01:01 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:03 [error] 627#627: *18 no live upstreams while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/photos/service-worker.js HTTP/2.0", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com", referrer: "https://nextcloud.myaddress.com/nextcloud/apps/photos/service-worker.js"
2023/01/19 00:01:22 [error] 627#627: *47 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/theming/manifest/settings?v=2 HTTP/2.0", upstream: "fastcgi://unix:/var/run/php/php7.4-fpm.sock", host: "nextcloud.myaddress.com"
2023/01/19 00:01:22 [error] 627#627: *47 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/theming/manifest/settings?v=2 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:01:30 [error] 627#627: *55 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:30 [error] 627#627: *56 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:30 [error] 627#627: *57 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:30 [error] 627#627: *58 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:30 [error] 627#627: *59 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:31 [error] 627#627: *60 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:01:31 [error] 627#627: *61 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:02:02 [error] 627#627: *64 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:02:02 [error] 627#627: *64 no live upstreams while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://php-handler", host: "nextcloud.myaddress.com"
2023/01/19 00:03:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:04:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:04:47 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:05:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:06:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:07:04 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/remote.php/dav HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:07:46 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:08:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:09:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:09:57 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:11:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:11:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:12:04 [error] 627#627: *166 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:13:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:14:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:14:58 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:16:00 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:17:31 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:17:59 [error] 627#627: *212 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "REPORT /nextcloud/remote.php/dav/addressbooks/users/myusername/contacts/ HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:19:35 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:20:35 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:22:37 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:23:59 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:25:37 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:27:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:28:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:29:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:29:59 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:31:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:32:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:33:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:33:30 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:34:31 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:35:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:35:58 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:37:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:38:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:39:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:39:59 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:41:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:42:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:43:01 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:44:37 [error] 627#627: *18 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:45:37 [error] 627#627: *430 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:46:16 [notice] 5936#5936: signal process started
2023/01/19 00:46:38 [error] 5938#5938: *437 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:47:59 [error] 5938#5938: *435 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:48:08 [notice] 6680#6680: signal process started
2023/01/19 00:48:37 [error] 6682#6682: *449 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:50:37 [error] 6682#6682: *447 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:52:37 [error] 6682#6682: *447 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:53:39 [error] 6682#6682: *472 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "OPTIONS /nextcloud/remote.php/dav/principals/users/myusername/ HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:55:37 [error] 6682#6682: *447 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:55:39 [notice] 7518#7518: signal process started
2023/01/19 00:56:37 [error] 7520#7520: *494 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:58:11 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:59:26 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 00:59:59 [error] 7520#7520: *516 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:01:01 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:02:01 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:02:54 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:04:01 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:04:59 [error] 7520#7520: *492 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PUT /nextcloud/apps/user_status/heartbeat HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:05:29 [error] 7520#7520: *569 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "PROPFIND /nextcloud/remote.php/dav/calendars/myusername/ HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:06:15 [notice] 7815#7815: signal process started
2023/01/19 01:06:32 [error] 7816#7816: *585 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:07:31 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:08:37 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:09:15 [error] 7816#7816: *604 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:10:01 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:11:01 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:11:59 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/csrftoken HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:13:00 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:13:57 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/settings/admin/logging HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:14:28 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/poll?lastReqId=4Yr481PISv61c2v1sdk6 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:14:47 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/get?offset=100&count=25&levels=11111 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:15:11 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/poll?lastReqId=4Yr481PISv61c2v1sdk6 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:15:34 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/poll?lastReqId=4Yr481PISv61c2v1sdk6 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:16:03 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:16:33 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:17:03 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:17:33 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:18:03 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:18:45 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/poll?lastReqId=4Yr481PISv61c2v1sdk6 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:19:03 [error] 7816#7816: *768 connect() failed (111: Connection refused) while connecting to upstream, client: 2001:19f0:5:3f52:5400:3ff:fe7e:42bf, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/richdocumentscode/proxy.php?req=/hosting/capabilities HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
2023/01/19 01:19:33 [error] 7816#7816: *583 connect() failed (111: Connection refused) while connecting to upstream, client: 50.207.162.131, server: nextcloud.myaddress.com, request: "GET /nextcloud/apps/logreader/poll?lastReqId=4Yr481PISv61c2v1sdk6 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "nextcloud.myaddress.com"
EDIT 2: I also DID go downt eh rabbit hole of searching for the problem already, and I coudln’t find anything to solve my problem.
