Hello.
I’m unable to update / upgrade nextcloud as OCC says it’s already at latest version. What’s wrong ?
Regards
Cédric
Nextcloud version : 25.0.2 RC1
Operating system and version: debian 11.6
Apache or nginx version : nginx/1.18.0
PHP version : php-fpm 8.1.15
to replicate it:
sudo -u www-data php occ upgrade
Nextcloud is already latest version
nothing related to issue
'default_language' => 'fr_FR',
'defaultapp' => 'files',
'updatechecker' => false,
'instanceid' => 'oclrkv9vbjjn',
'passwordsalt' => 'nBbt0xxxmT',
'secret' => 'kKVN+igo6fcxxxWTL',
0 => 'nextcloud.xxx.fr',
'datadirectory' => '/data/nextcloud/',
'overwrite.cli.url' => 'https://nextcloud.xxx.fr',
'version' => '25.0.2.0',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbuser' => 'owncloud',
'dbpassword' => 'xxx',
'allow_user_to_change_mail_address' => '',
'logtimezone' => 'Europe/Paris',
'apps_paths' =>
0 =>
'path' => '/var/www/nextcloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/www/nextcloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'theme' => '',
'loglevel' => 2,
'mail_domain' => 'xxx.fr',
'mail_smtpmode' => 'smtp',
'default_phone_region' => 'FR',
'mail_smtphost' => 'smtprelay.xxx.fr',
'mail_smtpport' => '25',
webserver not involved (fpm), no logs in fpm
no error logs
